Results 1 to 4 of 4
    Nov 02 2007
    03 B6 1.8T TIP
    Richmond
    Aftermarket Alarm ByPass
    Searched it up, can't find any answers
    Here is my story:
    Bought a B7 remote and cut the key already, swapped the B6 transponder into the B7, great!! IT doesnt work!! Here is my potential solution since i love the B7 remote:
    - Buy an aftermarket alarm system (2 way with remote start)
    - Get a guy to install it (cause i suck at installing things) with a bypass module
    and bypass it
    - Start using the new LCD remote for keyless entry and starting my car with my new B7 key and my friend can help me program the B7 remote to do keyless entry for me too and pop the trunk.
    **Question, will this work??, need answers ASAP cause my car is still at my company 20min away from my home**
    "When you love somone, you let her sleep well"
    My...2005
    Coiming this Summer: VIS Carbon Trunk w/carbon lip spoiler. CF splitter...
    "The fastest B6 TIP in Richmond BC"
    Veteran Member Three Rings ziggituning's Avatar
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    Re: Aftermarket Alarm ByPass
    sdure it will work, only trhing will be to have the transponder bypassed to use the remote start, the aftermarket alarm will just splice into exisitng wires, so if you ever get the oem fob working it shoul work, only issue will be that the B7 fob, will not deactivate the remote start alarm, unless the installer rigs some signal wire off the alarm to deactivate the remote alarm. In any case it is not big deal, prices are from about 3000-700$ depending on brand and where it is installed. I would just get a plain key with a transponder in it (ebay) and use the remote start remote, and dump the oem fob alltogether.
    PARTS FOR SALE: LW Crank Pulley, OEM injectors, ABT rep grill, OEM Intercooler, PM me.
    For your OEM HID D1S/D2S/D3S and HID conversion [Headlights/Foglights], and Interior/Exterior LED needs, send me a PM![/SIZE]
    Nov 02 2007
    03 B6 1.8T TIP
    Richmond
    the thing is, i did not get the tranponder to work when i put it into the b7 key, so i need the aftermarket alarm to bypass it and get my B7 key(without any transponder) just for cranking the car up and the remote from the aftermarket alarm for keyless entry, we will worry about the remote start later, because right now my car can't even start.
    My...2005
    Veteran Member Four Rings aLeXliu911's Avatar
    Sep 14 2006
    2003 A4 1.8T QM
    Vancouver
    i bought a few b7 key on ebay, but only one of them comes with a transponder.
    BetaAlphaTau member #11
    2003 A4 1.8T 5SpdMQ Black
    545awhp, 477.4awtq
    Stasis Motorsport C/O
    Stasis Center Diff
    Stasis Rear LSD
    Stasis Alcon BBK
    Status Carbon Fiber Seats. ER Comp FMIC
    2008cc, AWM, Ported AEB Head, HTA GT3582R,Full Race Exhaust Manifold, INE Intake Manifold
