Results 1 to 14 of 14
    Veteran Member Four Rings rxrep's Avatar
    Feb 28 2006
    has nothing in it but memories.
    Pittsburgh-Philly
    Test FIRE. Promise, no CF content, finally.
    Got single LED's yesterday. Set up 13 and played with the relay-resistor setup I made.
    Here is video of the LED's going from bright to dim. Thanks to Kirk on the LED hook-up. These things are so bright when full on that I couldn't run the video directly on. Had to do it from the side. I can still mess with various resistors once on the car to get the best dimming effect when the headlights come on.
    Any DIY-ers out there who want to do this to their LED's... it's a $10 mod.
    Clicky
    My 2004.5 APR Stage 3+ is SOLD
    Veteran Member Four Rings Turbo1A4's Avatar
    Aug 04 2008
    2002 s4 nogaro
    Jax
    Re: Test FIRE. Promise, no CF content, finally.
    nice cant wait to see the final product
    Jun 08 2008
    Calgary AB Canada
    pretty slick.
    Feb 28 2006
    Pittsburgh-Philly
    Posting here because, well, they ain't done, and I don't want to start a new thread until they are. Just a test fit of the LED's in the manner I want them. The trim of them is ghetto still.
    And to show some of the ghetto trim... It will be overlayed and trimmed up to exact fit.
    And finally, link to video of passenger side LED's on in car from different angles.
    Clicky
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Are blazin' a fatty in that video? Don't worry, about a thing, every little thing, gonna be alright!
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Feb 28 2006
    Pittsburgh-Philly
    Lol. Gotta love shuffle play on a songlist. Glad it at least caught that song. Let's just say my musical tastes have a very broad range.
    As for the fatty.... I can only imagine what I'd cover in CF if that where the case.
    Veteran Member Four Rings PRY4SNO's Avatar
    Jun 28 2007
    1990 Coupe quattro with all the parts
    Edmonton, AB
    That's a great idea, Lee. I love the look of LEDs.
    How come they don't appear to be lined up straight? Is it a depth issue?
    2013 Touareg TDI Execline /// Farmenwagen: Malone 2.5 tune, Darkside & Rawtek Delete
    1992 80 quattro 20v /// Eventual AAN'd Winter Sled
    1990 Coupe quattro /// Because Racecar
    Feb 28 2006
    Pittsburgh-Philly
    Not sure I understand. The line of LED's follows right on top of the curve of the bottom trim piece at the point where it becomes ribbed and goes downward.
    That is not the same curve as the front portion at the clear housing. It is wider towards center, and not deep at all and the turn signal end.
    I'm sitting on it until next weekend and then coming back to it fresh to see if I still like it.
    Veteran Member Four Rings TonyD's Avatar
    Aug 11 2007
    2012 135i tuned+meth'd
    California
    Did you bake the headlights or heat gun them open?
    Jun 30 2007
    Raleigh, NC
    Quote Originally Posted by Tony@Autobahn View Post
    good question - because you joey modded your lights along with the few other brave ones of us way back when... how in the HELL did you get your lights back apart?
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Feb 28 2006
    Pittsburgh-Philly
    Heat gun. These aren't the same housings. I bought real dirt cheap ecodes with a few minor internal problems (plastic tabs broken on turn signals; easily fixed. So, I canabalized the projectors out of my old joey modded US housings (I cut the clear housing off because I knew I wasn't using it again), and used the new housings of the ecodes for this project.
    I'm not trying to toot my own horn, because it just comes with doing it a lot, but I can now get the housings part without any bend in the black lip on the top. So, in effect, when looking at the housing with the hood open when the headlight is re-installed, there doesn't appear to be any indication that they were ever separated. I used to bend the top lip and then reform it with the heat gun, but that still showed minor flaws and waves across the top. Not no 'mo.
    And these housings will be sealed with.... yep... Plumber's Putty. Because I will need to get them back apart to change LED's if they ever burn out. I've formed a couple tiny clamps out of metal that will hold the housing halves together. They will be placed along the side and bottom so they can't be seen. And the plumber's putty will seal more than adequately.
    Senior Member Two Rings inaforest's Avatar
    Sep 10 2008
    is full of junk.
    Los Angeles, CA
    i want.
    Aug 11 2007
    California
    Any tips on opening up the headlights? It's irritating the shit out of me and I just gave up for tonight.
    Veteran Member Four Rings Spinnetti's Avatar
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Me likey.. cool stuff..
    2008 R8 V8 Manual: Uni 93 ECU tune * Avior Exhaust * Spacers * R8 Puddle lights * Custom mats. All 12 of my other VAG cars are gone :(
