Results 1 to 4 of 4
    Jul 29 2007
    Toronto, ON
    Check Engine & Almost Stalling
    Go to get in the S4 today, start it up and really rough idle (it's snowing). The car idles at 1,200rpm but as the engine heats and rpms drop idle gets really rough. Check engine comes on and car almost stalls when it hits 800rpm.
    Sound familiar to anyone?
    2006 Black S4
    AZ Members' Properties Bought/Sold: 6
    Veteran Member Four Rings YZracer's Avatar
    Sep 20 2005
    Scottsdale, AZ
    Re: Check Engine & Almost Stalling
    My car did that too with full throttle problems on top of that, but the rough idle would go away when the car warmed up so ya got me whats up with your car. My car had bad EGT's
    CURRENT TOY
    2013 TT-RS Ibis White - Stock for now......
    Sold:
    2010 B8 S4 Phantom Black: Stasis Touring Suspension Kit, APR Pulley, APR 93 Octane Pulley Tune, APR Full Carbonio Intake
    Parted and Torn down:
    2000 Black 6spd S4
    SSP Tuned PJK04 Stage 3
    Burned:
    2000 S4 Tiptronic (B5)
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    could be a major boost leak. Check your hoses and do a pressure test with soapy water.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Jun 14 2007
    2000 S4
    Connecticut
    check that code, it will more than likely point you in a good direction...
    It sounds like a boost leak, that or some pretty bad misfiring... What does the idle hold in vacuum on the boost gauge?
