    Veteran Member Four Rings Kronic Budz's Avatar
    Oct 01 2007
    1997 A4 2.8 QM
    San Diego, California
    suspension question
    Ok well comparing my car to my friends 03 coupe g35. Why is my suspension firmer or just as firm as his? His car is on stock sport suspension and my car sits just a little bit lower then his, not much. He has a 3 finger gap and i have a 2-3 finger gap. Him being on 18's and me on 16's. His tires being staggered 245/45/18 in front and 275/40/18 in rear. Mine being 205/55/16 all around. My suspension has only 1000 miles on it being bilstien/vogtland sport shock combo.
    his car barley has an give when you push down on the corners of the car and mine has noticeably more... Why is that? is that springs or shocks or both together? Does that determine how much body roll the car is going to have. If he can push down less on his car then mine, then why would my car take bumps in the road rougher then his??
    just out of curiosity.
    1997 Audi A4 2.8 QM black on black
    bilstein sports w/ vogtland sports ~ S4/sport sway bars ~ 17x8 Bremmer Kraft Br05 wheels et33~ BF G's Sport COMP 2's 225/45/17 ~ Custom Exhaust ~ CAI ~ Ebay SS ~ SS brake lines + EBC red stuff ~ 35% tint/70% front tint ~ face lift headlights w/ 5000k HID + tails ~ blacked out grill trim~ kenwood mp3 ~ Polk comp 5.25" Front mm speakers ~ Infinity REF 6.5" rear speaks ~ 10" Rockford Fosgate p2 in sealed box ~ ED nine.4 4ch. amp powering woofer/polks[/I]
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    Re: suspension question
    it is a completely different suspension system. Everything is going to react and work together differently....as far the having "give" that is a combination of both I believe. Different springs have different load ratings ect..
    Veteran Member Four Rings Kyle H's Avatar
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Quote Originally Posted by Kronic Budz View Post
    His car came from the factory as a performance oriented car, so they designed the shocks and springs along with the suspension geometry to all work together for the weight and ride height it hsa. I'm probably going to get some flack for saying this, but spring/shock combos really aren't that great for performance on our car. In my experience the bilstein sport shocks' rebound dampening is too low for the spring rates that the major companies use, leaving the car rough and/or bouncy...
    The body roll has a couple of different factors, he may have less than you but it really depends on the cars suspension geometry, weight, weight distribution, traction, shocks/springs, and sway bars.
    "Einstein: Any man who can drive safely while kissing a pretty girl
    is simply not giving the kiss the attention it deserves. "
    because racecar.
    Dec 14 2006
    Halifax, NS, Canada
    i think those cars are also dual wishbone front and rear where ours are McPherson strut design.
    2001.5 1.8T Manual Quattro Celebration | Startup Racing Vogtland Coilovers | Giac X Chip | SPP A pillar with VDO Gauge | Boxster/A8 Front brakes S4 rears | Neuspeed Catback VMR Testpipe |
    NOW DEAD :(
    Oct 01 2007
    1997 A4 2.8 QM
    ok this makes it a little more clear. His car is 51/49 weight distribution as well. Our cars are like what 58/42?
