Results 1 to 29 of 29
    Veteran Member Four Rings BlackB6's Avatar
    Apr 03 2008
    Pennsylvania
    Wiper fluid does not work..
    Bought the car with this problem. My windshield wiper fluid device is not working. Fluid is full, and when I try working it, I hear no motor or anything. Anyone experience the same problem? What parts do I need to fix the problem? Any help would be great, thanks..
    Veteran Member Four Rings T0M3K's Avatar
    Sep 14 2007
    Valley Stream, NY
    Re: Wiper fluid does not work..
    Check fuses first, then maybe your pump is bad.
    Veteran Member Four Rings ryannorthcott's Avatar
    Jul 10 2008
    2002 A4 1.8T Quattro
    Kelowna BC
    ahh same problem!
    just started though the other day...
    sorry i have no advice
    two thousand two audi a-four quattro five speed
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Check fuse #37. It is probably blown. Replace it with a 30amp fuse as per an Audi TSB from several years ago.
    Veteran Member Four Rings KPC1.8TQuat's Avatar
    Mar 20 2006
    2003 A4 1.8T Quattro, 2006 Triumph Daytona 675
    North Shore, New England
    Ah yes, I was just going to ask this today. I keep blowing fuse #37, and have been replacing with a 15 amp fuse because that is what was in there origionaly. So, 30 amp is fine for #37?
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by KPC1.8TQuat View Post
    Yes. I just confirmed it in the Bentley. It clearly states to use a 30amp fuse in position #37.
    (TSB 92-05-02) Headlight Washers Inoperative June 16, 2005
    Veteran Member Four Rings JMRQuattro's Avatar
    Jul 04 2008
    Seattle, Washington
    I have this same problem too. PITB driving up and down the mountain, i gotta keep windex and towels on me so i can stop to clean my windshield every so often.
    - Justin -
    Veteran Member Four Rings heateris's Avatar
    Aug 16 2004
    08 A4 2.0TQM6 ~ 08 Highlander Sport
    SE PA
    the # 37 fuse blows when the headlight washers are frozen shut, thus killing the washer system.
    Jul 04 2008
    Seattle, Washington
    I read somewhere if you turn the power on, but don't start the car, and try to use your windshield wiper fluid, if you listen for the pump and you can hear it you probably have a clog. I guess if the fuse goes out the pump won't run.
    - Justin -
    Veteran Member Four Rings A6.S-line's Avatar
    Nov 29 2008
    NYC and NJ
    I had the same problem on NYE, turns out whatever fluid was in the reservoir from before wasn't winterized, so it had frozen in the pipes. Was working again the next afternoon....
    Sep 13 2008
    Western Chicago Burbs
    i have the same problem and its not the fuse as i have replaced them many times. so i have no clue what to do now
    Jul 04 2008
    Seattle, Washington
    Quote Originally Posted by B6JoeA4 View Post
    check for a clog
    - Justin -
    Sep 13 2008
    but everything including the winshield and headlight washers dont work. i can even hear the pumps running
    Jul 04 2008
    Seattle, Washington
    If you can hear the pump running then it should be a clog from my understanding. Cause if you hear the pump that means the fuse is ok because the fuse controls the pump. At least that's what i found online.
    - Justin -
    Mar 20 2006
    Quote Originally Posted by heateris View Post
    I don't think my headlight washers have ever worked.
    Veteran Member Four Rings gotboost's Avatar
    Nov 04 2007
    Minnesota
    same problem here, just started a few weeks ago
    Current:
    2002 A4 Avant - Eibach Pro Dampers | Rev Motoring Springs | 034 Motor Mounts | 710N DV | Apikol Snub Mount | 18" S4 Peeler's
    2001 Imola S4 Satge 2+
    2003 A4 GT2871r 303 AWHP 291 AWTQ
    Veteran Member Three Rings ziggituning's Avatar
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    you have a few possible things, as Old Guy said the fuse is the first, replace with a 30amp, if you have a test light see t there is power at the fuse in case you have a break in the line (just in case).
    Then if the fluid may be suspect and frozen in the system they make sure the car in put in a warm place and see if this cures the issue.
    if not you can remove the drivers side headlight and get access to the 2 pump motors, one with smaller gauge wires is the one pumping to the hood, the other is for the bumper. Take your test light and a friend and see if you have power when you try and activate the pumps, if you have power and hear nothing the pumps may be seized or burnt, replace and then all should be OK.
    if you have no power then the wires may be damaged somewhere.
    I have seen pumps seize up if they were not used for a long time, or just bad luck. Hope this helps.
    I unplugged the pump to the bum per to avoid the frozen bumper washer situation alltogether, plus I hated flooding my light with all that fluid.
    good luck.
    PARTS FOR SALE: LW Crank Pulley, OEM injectors, ABT rep grill, OEM Intercooler, PM me.
    For your OEM HID D1S/D2S/D3S and HID conversion [Headlights/Foglights], and Interior/Exterior LED needs, send me a PM![/SIZE]
    Sep 13 2008
    Quote Originally Posted by SeatownB6 View Post
    i meant i CANT hear the pumps running
    Jul 04 2008
    Seattle, Washington
    Oh, well then it's probably either your pump or the fuse.
    - Justin -
    Senior Member Two Rings BRSox307's Avatar
    Aug 16 2007
    #37 is a 20amp in my manual
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    Quote Originally Posted by ziggituning View Post
    good luck.
    never mind your manual, there is a service bulitin on this, so just go 30amp, as for the rest look at the above text.
    Jul 10 2008
    Kelowna BC
    just replaced the fuse now and it works like a charm.
    thanks guys!
    and to think i was gonna take it in to a mechanic...
    Sep 13 2008
    i cant hear either of the pumps ruinning. i doubt that both are shot. i have replaced the fuse many times. i might end up just taking it to renn art
    Dec 01 2007
    Orange County, NY 10918
    The 30 amp fuse isn't working on mine. Just keeps blowing. What could be the problem. The headlight ones don't work, could they be fucking everything up?
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    @skiguardusa www.skigaurd.com
    Jul 04 2008
    Seattle, Washington
    Joe:
    Maybe they got unplugged. I just found out today that mine got unplugged and that's why they don't work. The previous owner disconnected them for some reason.
    - Justin -
    Sep 13 2008
    so somehow someone or something unplugged my headlamp and winshield washer pumps? doubt it. i am the only one who works on the car.
    they allways worked and then one day, they just stopped working.
    is there a wiring harness that leads to both of the pumps?
    Jul 04 2008
    Seattle, Washington
    haha i didn't know that they had previously worked for you. But i have no idea. I'm out of ideas. Maybe it's just a coincidence that both pumps with out at the same time or something haha. Really don't know what else to tell you. Cause if you replaced the fuse, and still nothing, and the pumps don't operate you probably don't have a clog. And they're obviously plugged in. So i'm just gonna go with your pumps went out. That really seems like all that's left
    - Justin -
    Nov 04 2007
    Minnesota
    well my fuse was also blown, changed it out with a 30amp, and now works fine, thanks for this thread
    Current:
    Aug 16 2004
    SE PA
    Quote Originally Posted by gotboost View Post
    good. the headlight washers only spray when the headlights are on. i you get winter weather try to clean off your front bumper.
