Results 1 to 15 of 15
Thread: Oil Light!!!!!
    Oct 21 2008
    2003 Audi A4 1.8t
    Dallas
    Oil Light!!!!!
    Hey last night i was driving my car pretty hard with a couple of my boys. We started just fly down the high way doing about 100 to 140.. and after we slowed down my oil light started coming on and off. This morning i check my oil level and its fine and at the correct level. I smelt some oil burning when i would come to a complete stop.Do you think i messed anything up/ I only have 63000 miles on it and i use Castrol Full Syntheitc..
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Re: Oil Light!!!!!
    Was it the yellow oil can symbol (Check engine oil level) or the red oil can symbol (Engine oil pressure too low)?
    Sep 13 2008
    Western Chicago Burbs
    Re: Oil Light!!!!!
    i get the red one all the time when i run it hard. i think its a bad sensor
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    Re: Oil Light!!!!!
    could be
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Re: Oil Light!!!!!
    Quote Originally Posted by illaudiill View Post
    could be
    I can't believe you don't have 4 rings yet.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Veteran Member Three Rings cdn20valve's Avatar
    Oct 09 2007
    B6 A4 Avant
    North Toronto
    Re: Oil Light!!!!!
    VW's don't really have problems with oil pressure senders being faulty.
    Oil odour at idle is evidence of an oil leak. Check the engine for leaks. If possible pull one of the intercooler hoses off and see if there is excessive oil in the intercooler piping. If there is you might have blown a turbo seal.
    Worst case scenario is oil sludge. But before you freak out, run some visual tests and look for oil leaks.
    There are pressure tests you can do at idle and approx 3000rpm using a pressure gauge. If you have the know-how/tools.
    Sep 13 2008
    Re: Oil Light!!!!!
    Quote Originally Posted by cdn20valve View Post
    yo know a lot for a one ringer.
    what about us 3.0 guys? 3.0s are not known to have sludge problems and there isnt much room in my engine bay to do much visual inspecting
    Oct 09 2007
    B6 A4 Avant
    North Toronto
    Re: Oil Light!!!!!
    Quote Originally Posted by B6JoeA4 View Post
    I'd get a small mirror and check around. You could also run pressure test with the right equipment.
    Dec 28 2006
    Western Maryland
    Re: Oil Light!!!!!
    Quote Originally Posted by Malustunna View Post
    There are three different oil warning lights. Two of them are yellow, both show an oil can symbol. One says "MIN" for low oil. The other says "SENSOR" indicating a problem with the oil level sensor. The third is a red oil can. That one should be of some concern especially if your oil level is OK. The red warning indicates low oil pressure. It could be the oil pressure sensor but as cdn20valve pointed out they typically do not go bad. The other possibilities are worn bearings, worn oil pump, or the infamous 1.8T sludge issue. Since you just came off a high speed run your oil temperature was probably pretty high and consequently the oil was thinned out a bit. If you are developing a problem it is going to show up when your oil is thin. I would recommend taking your car to a shop that has the ability to measure your oil pressure. You should also consider taking steps to de-sludge your engine in case your oil pick up screen is partially clogged. I recommend running a dose or two of Auto-Rx. I have had good luck with that in the past when dealing with old abused engines. Seafoam is another product that seems popular here but I have no first hand knowledge of the product.
    If it was my car I would definitely take some proactive steps and not take a "wait and see if it comes back" approach to the low pressure warning light.
    good luck!
    Veteran Member Three Rings ziggituning's Avatar
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    Re: Oil Light!!!!!
    X2 what old guy said. Better safe than sorry!
    PARTS FOR SALE: LW Crank Pulley, OEM injectors, ABT rep grill, OEM Intercooler, PM me.
    For your OEM HID D1S/D2S/D3S and HID conversion [Headlights/Foglights], and Interior/Exterior LED needs, send me a PM![/SIZE]
    Veteran Member Four Rings KPC1.8TQuat's Avatar
    Mar 20 2006
    2003 A4 1.8T Quattro, 2006 Triumph Daytona 675
    North Shore, New England
    Re: Oil Light!!!!!
    Care to elaborate on this product?
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    Re: Oil Light!!!!!
    do a search for auto-rx and/or seafoam,there are countless threads on it, they are prety much the 2 main products used by many on this forum, both clean out the engin (possible sludge). Since our cars run hot and are picky on what oil they run, it is good to do some sort of engin clean out treatment each year or two.
    Dec 28 2006
    Western Maryland
    Re: Oil Light!!!!!
    Quote Originally Posted by KPC1.8TQuat View Post
    It is a product developed to dissolve build up in your motor. Their website is pretty helpful. Read through the FAQ's section. Clicky click I've used it on older engines that have seen considerable abuse before tearing them down for rebuilds and it does a pretty good job of cleaning them up.
    Cheers!
    Edit: Auto Rx on a 1.8T
    Mar 20 2006
    Re: Oil Light!!!!!
    Cheers!
    Interesting read....
    If my car shows no sign of sludge, is this still a good idea to run?
    Dec 28 2006
    Western Maryland
    Re: Oil Light!!!!!
    Unfortunately for most, the first sign is a red "Low oil pressure" warning light. Unless you have opened up some portion of your engine (valve cover, turbo oil return line etc) you would probably be completely unaware of the issue until it bit you. On the other hand, if you know your car's complete maintenance history (5k oil and filter changes with synthetic oil only) you really don't have anything to worry about. It was the earlier 10K dino oil changes VW/Audi recommended that caused the problem.
