Results 1 to 3 of 3
Thread: how do i???
    May 06 2008
    minnesota
    how do i???
    how do i flush the heater core?? any pics???
    Account Terminated Three Rings pzp107's Avatar
    Dec 02 2007
    State College pa
    Re: how do i???
    Your not gonna be able to see your heater core unless you tear into your dash. It is part of your fan assembly as the fan blows air across the core to get heat. Radiator with directed flow lol. However you flush it by flushing your cooling system. Make sure when you run it through your cooling system you keep the heat on high and full blast and have teh car warmed up fully for a few minutes. The isntructions on teh flush will usually tell you.
    Jul 01 2008
    Minnesota
    Re: how do i???
    The lines are on the right of the A/C lines in the middle of the engine bay. They are covered by that plastic oval covering. You can get to them without pulling apart the dash, you just have to pull the dash if you want to replace it. http://www.audiworld.com/tech/int54.shtml youll see them on the first few steps of that writeup.
