Results 1 to 7 of 7
    Nov 27 2008
    miami,fl
    inner fender question
    going to be lowering my a4 this month with vogtlands and gonna be buying some rs4 reps from vmr as some stocks and im wondering if anyone trims or even removes their inner fenders. i plan on riding as low as possible meaning no fender gap on 19x8.5s. any info or pictures is appreciated.
    Veteran Member Four Rings Grishbok's Avatar
    Apr 15 2008
    Reston
    Re: inner fender question
    not unless 100% nescessary, but what some people do is...
    on the center of the top of the inner fender liner, right on the outside edge, theres a part (looks like ar ubber tab) that is on the outside of the fender. Some people remove that and tuck it up under the fender.
    2008 A4 Quattro Brilliant Black
    *SOLD*
    StreetTunedTV.com
    You are violating the 3 rules of forum posting.
    1. Title thread appropriately
    2. Use the search first
    3. If you didnt find what you were looking for, its because someone else didnt follow #1.
    Veteran Member Four Rings Phrost's Avatar
    Jan 24 2007
    1977 VW Type 2 Westfalia
    Wisconsin
    ^ yup, and remove the torx screw where that tab thing is.
    You should be fine unless you really slam the car. With my last car, I ended up rubbing only once in a while when I'd hit bumps so I really didn't care. Some people don't mind rubbing at all, some want none... I guess figure out how low you want it and you'll do what you have to do
    Ignorance is bliss.
    Jun 14 2005
    Anaheim, CA
    You should be ok by bending up the tab after removing the screw. You should use a heat gun just in case.
    Be sure to post some pictures! :)
    -Charles@VMRWheels
    Brandon @ VMR Wheels
    Nov 27 2008
    miami,fl
    Quote Originally Posted by VMRWheels View Post
    -Charles@VMRWheels
    yea i will. its gonna be a few weeks im going to do suspension, sway and brakes all at the same time cuz im using the lift at my job on an off day. the wheels will be shortly after when tax money rolls in....
    Jun 14 2005
    Anaheim, CA
    Quote Originally Posted by toxxin View Post
    Very nice! It will be fun putting on all the goodies the same time.
    -Charles@VMRWheels
    Veteran Member Four Rings eskimopunk's Avatar
    Mar 26 2008
    63 Ford Falcon Futura Convertible
    Las Vegas
    i took out the screw and rolled my front fenders. i just borrowed my friends fender roller and it was all good after that
    flickr
    "ALL I REMEMBER IS ARGURFIN WITH DRCURITY AND THEM KICKING me out of neptunes i ve had like 6 LIT's biches is crazy my backj fucking hurts" - El_Chapusca
    SBSC Designer
    For awesomeness. Thanks Pat.
