Results 1 to 8 of 8
    Jul 03 2008
    New Jersey
    Front Wheels Camber
    How do you adjust the front wheel camber?
    Buncha motorcycles
    Memphis, TN
    Re: Front Wheels Camber
    buy stern adjustable upper control arms
    APR Stage 2/AWE Intake
    Jul 03 2008
    New Jersey
    So there is no adjustment for camber for the font wheels with the stock suspension...only aftermarket?
    Veteran Member Four Rings AudiOso's Avatar
    Aug 04 2007
    Do Hotwheels count?
    Boardman, OH
    How low is your car? My car is 25.25" at the top of the fender lip and I have no problem with the camber. Your car must be dropped pretty far.
    A couple of Audi's later...
    "It's a false state of elation... You can join the Prozac nation... If you want to..." - Killing Joke
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    Quote Originally Posted by Scourie View Post
    Correct.
    -Darrick
    Mar 27 2005
    The Cold North
    correct. camber in the front is dictated by ride height. if you want adjustablity there are adjustable upper control arms avaliable. ~$5-600 a set.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Aug 26 2005
    The camber on a stock setup, lowered or not, can only be adjusted to equalize the camber side to side by moving the subframe.
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    You can adjust the toe angle up front. That's it unless you go for aftermarket adjustable control arms. At a ride height of 25", there's no need for camber adjustment. If you go lower, then you should look for adjustable arms.
    USP CLUB MEMBER #34
