Results 1 to 8 of 8
    Senior Member Two Rings Fizikal S4Avant's Avatar
    Aug 03 2008
    2010 GT3, 2013 S4, 2018 Q5, 2020 Model 3
    Mill Valley, CA
    Shifting getting a little notchy.
    Shifts are not feeling as smooth as they used to. Sometimes it almost feels as if it is clicking into gear. What is this a sign of? Thanks in advance.
    B8.5 S4, 997TT, VW TDI Sportwagon
    Senior Member Two Rings RamrodA4's Avatar
    Sep 09 2007
    GSX-R 750
    Re: Shifting getting a little notchy.
    yeah same here...
    2011 Audi S4
    May 16 2008
    South Texas
    Which gears? 1-2? If you have a 6 speed then it's probably the syncros are worn or shift collar is buggered and soon it won't shift at all!
    Aug 03 2008
    Mill Valley, CA
    Good info. I would assume this would be covered under warranty? It does it in 1st 2nd and 3rd.
    Veteran Member Four Rings JOS4AUDI's Avatar
    Jul 09 2008
    2008 RS4, 2012 S4, 2013 Allroad
    So Cal
    wow my b7 s4 does the same thing. Its 1st 2nd and 3rd and for a while it was hard to get into reverse i finally took it into the dealer and they fixed the synchros and reverse works better.I was driving it the other day and 1st 2nd and 3rd are still hard im thinking when i have time i will take it back.please keep me updated.
    Senior Member Three Rings jessefrank's Avatar
    Jan 09 2006
    Q7.Prestige.S-line.Pkg.2
    Rapid.City
    One thing to check is the fluid level. I've experineced this myself on my 5spd. Just refilling it to the proper level made a huge difference for me (since I had a seal leak and lost .5 quart or so). I've also heard of a overfilling the trans by just a little helps smoothness too and I'm actually getting some more Redline to try this on mine.
    Quite a few people on AZ say that switching fluid helps shifting too (Redline MT-90 or Motul Gear 300)...but I just did the switch to Redline MT-90 and my shifting is acutally harsher with the new fluid than stock blend filled to the proper level .
    Jun 14 2005
    Anaheim, CA
    Notchy shifter could come from the kind of tranny fluid you are running. Each manufacturer has a different viscosity even if it is labeled the same.
    -Charles@VMRWheels
    www.vmrwheels.com
    Brandon @ VMR Wheels
    Veteran Member Three Rings handyvorb's Avatar
    Jan 31 2009
    '04 S4, '95 Eagle Talon MSnS
    Huntsville, AL
    Umm, I take it you guys tried adjusting the shifter first? No? Spec for the 6-speeds is the shifter pushed ~2* to the right on the X axis (sometimes more is better) and centered on the Y axis. Play with the adjustment, and see how it feels.
    Joel Baldridge
    Stage 4 Audi Technician (Master Guild Certified)
