Results 1 to 4 of 4
    Registered Member One Ring overland04's Avatar
    Jan 10 2009
    Mamaroneck, NY
    Another temp sensor question
    Problem: Car takes FOREVER to warm up! (like 60 miles or so)
    I had the gauge reading wrong for a while so I replaces the sensor behind the motor over the summer. Than I was able to see how long the car took to really warm up. I didnt really care it took long cause it was summer and didnt need heat. Now it winter and it's cold!
    I did a coolant flush cause It was due anyway but that did nothing.
    I have noticed that the fans are turning on when I start my car sometimes but not always, even in the morning.
    Check engine light just came on yesterday with a temperature sensor fault. I dont know if its the one at the bottom of the radiator coolant hose or the sensor on the thermostat housing.
    Does this sound like a bad thermostat and sensor?
    2002 A4 1.8t quattro
    136,000mi
    Veteran Member Four Rings heateris's Avatar
    Aug 16 2004
    08 A4 2.0TQM6 ~ 08 Highlander Sport
    SE PA
    Re: Another temp sensor question
    i would replace the bottom sensor.
    Jan 10 2009
    Mamaroneck, NY
    Do you think that would prevent my car from warming up over a faulty thermostat?
    Aug 16 2004
    SE PA
    Quote Originally Posted by overland04 View Post
    i'm not sure but it may stop the fans from turning on at start-up.
