Page 1 of 3 123 LastLast
Results 1 to 40 of 81
    Veteran Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    HID + fog lights issue
    Hey, just put some hids into my fog lights. I wasn't able to contact the manufacturer today and im not sure if their open tomorrow. Anyways....they turn on but they flicker on and off and i get the light bulb out warning for both sides. Anyone else have this issue or know what i can do to fix it? thanks
    2007 A4 S-Line / Ti Pkg / Quattro / Bilstein Pss9 / JHM Short shifter / GIAC X+ chip / RS4 rear sway bar / 20% rear tint / 10mm front 15mm rear spacers / Forge DV / DTM CF replica rear lip spoiler / DTH CF roof spoiler / Cupra R front spoiler (not on) / Infinity BasslinkII sub
    looking for: CF front lip / S4 alum mirror hosing
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    Re: HID + fog lights issue
    sounds like the ones you got aren't drawing enough power. just like the rear plate lights. What did brand/kit did you get so people know so they can try to help.
    The usual things!!
    Resistor Install
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    I hope you didn't just get a cheap kit that was a dud, post more info
    Registered Member One Ring RODRIC1's Avatar
    Dec 10 2007
    SAN DIEGO
    You might need error cancelers which regulate the wattage as well as eliminate the bulb out warning. Mercedes tend to always need these as well.
    Red 04 S4 avant, tint, valeo headlights,
    RS4 exhaust, 3.5 inch tips, carbon fiber splitter,
    19" O.Z superleggra III, GIAC chip, Bilstein PSS9's,
    VAG mods, intake, tinted tails, HID fogs, blacked out grills, LED license plate bulbs and interior lights, Yellow BBK 6 piston Brembos w/ cross drilled rotors
    Senior Member Three Rings B7 Projectile's Avatar
    Aug 06 2007
    07 Audi A4 2.0T
    Lancaster, PA
    Quote Originally Posted by RODRIC1 View Post
    I have 35 Watt HID fogs using the stock wiring with no problems at all. If they are flickering, it sounds like you may have gotten a crappy set of ballasts. I have about 25,000 miles with these installed and have the fogs on for a good amount of the time.
    2007 Ibis Audi A4 2.0TFSI Ti Package
    Vorsteiner CF Hood.APR K04.APR HPFP.AWE Exhaust.AWE FMIC.034 HFC.KW-V2 CO's.Forge DV.3000k HID Fogs.Smoked Tails.Custom Intake.Heatshield.CC Mod.35%Tint.Blacked Rings.RS4 Rear Sway Bar.Podi boost gauge.
    Ah...so many pedestrians, so little time...
    DUH! an Audi
    los angeles, CA
    flickering could be a few things, bad connections, faulty ballast. I would check your ground wires to see if everything is ok, if you use oem ground, sometimes it might not do the trick.
    to eliminate the bulb warning, you need to use either a relay or resistors to trick the car.
    hope this helps!
    -randy
    Oct 16 2008
    South Florida - Ft Lauderdale
    Getting my set this morning from Autobahn. I'll let you know. And by the way, I have a pair of Hoen H11 for sale (only installed for 3 weeks) that will be posted in the Classified
    Account Terminated Four Rings
    Jul 10 2008
    06 A4 / 09 IS-F / 10 Cayenne
    Austin, TX
    What brand did you get?
    Apr 14 2008
    Milton VT
    I got a set from http://www.ddmtuning.com/hidkihidbuhi.html, i got the 55watt kit. You think the ballasts are rated too high for what the fogs lights (stock) can put out?
    Veteran Member Four Rings praudi's Avatar
    Jul 31 2007
    R8 power wheels , Tiguan and Ferrari F1 power wheels
    Tampa,Fl
    its easy all you need are resistors heres a link to them scroll down and they are diff types of relays u need relay A thats what i been running for a year now http://www.hidextreme.com/replacements.html
    Veteran Member Four Rings airbornerifleman's Avatar
    May 20 2008
    2013 Passat TDI
    Toronto Ontario, Canada
    You may eliminate both flickering and bulb out warning by adding a couple of caps.
    Check out this thread: http://www.audizine.com/forum/showthread.php?t=218964
    I had the flickering problem before I installed a set of caps but I never encountered a bulb out warning.
    2006 Audi 2.0T quattro Tiptronic
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    Oct 16 2008
    Quote Originally Posted by airborneriflema View Post
    Well, mine does not work at all
    They do if I connect them directly to the battery but if I use the car harness, they dont lit at all. I am fuck^$% pissed off
    Apr 14 2008
    Milton VT
    ^^^ have you tried flipping around the connector from the hid's to the connector on the car? mine didn't work if you connect it correctly (with the little notch fitting into the stock connector,,,but i cut off that notch so i can flip it around and it works)
    Oct 16 2008
    Quote Originally Posted by vtracer20 View Post
    yes, I did. Everything assembled and connected to the car harness, they don't work. If I take the same assembly and jump it with 2 wire to the battery, they do work!!! WTF
    I don't want to start the relay bullshit !!!
    Apr 14 2008
    Milton VT
    im gonna go with the cap idea first...if that doesn't work i'll go with the relay. Are the relays' just a cap in a nice package?
    Oct 16 2008
    What do you mean?
    Apr 14 2008
    Milton VT
    i mean....if you look at the relays, it's just a box with two wires..i was just wondering if it's just a capacitor inside that box.
    Oct 16 2008
    Here is a pic
    Apr 14 2008
    Milton VT
    so is that the relay that comes with the kit? looks exact same as what i got except i got the 55w ballast
    Oct 16 2008
    yep that's how the kit came. And you did not have any issue? Plugged directly to the harness? No fault code?
    Nov 12 2007
    Grand Junction, CO
    I'm sorry...but I don't see the point. The Hoen H11 bulbs match the Xenon and look great. Why are you both going through so much trouble to have brighter fogs? It seems like it's a big hassle for a marginally better result, at least from pics.
    Jul 10 2008
    Austin, TX
    Great. Thats the same kit im waiting to install. Did you get the warning code eliminators?
    Oct 16 2008
    Quote Originally Posted by 12sA4 View Post
    I am dealing with Nick and he certified me that this set should be code free. but for now, got to wait because it does not work at all.
    Nick (great Guy) is looking into it
    Apr 14 2008
    Milton VT
    im getting a code due the flickering......
    Oct 16 2008
    Is this new? or it happen since you installed them?
    Veteran Member Four Rings VZWalex's Avatar
    Feb 21 2008
    09 Q5 Ibis White
    Los Angeles, California
    The flickering is usually caused by a voltage irregularity that is commonly fixed with a capacitor to adjust for the voltage difference but in your case maybe the Warning Code eliminators from DDM tuning might take care of this. I would talk to Autobahn Exotics if they carry them.
    I will be ordering a set for my MKV this week as well. Im going to ask if they offer installation there. I rather not deal with the headache.
    15 Mazda Cx-5 metero Grey - Stock for now ...
    09 Q5 Ibis White. Prem+, B&O, ZiZa Pure Yellow Fogs, Clear Bra,Prestige tint,Tunerdome LED Plate Bulbs, VIM, Vag'd
    06 MkV 2.0T - Sold
    05 XB Silvermist. - Sold
    www.EurovisionProtectiveFilms.com
    Apr 14 2008
    Milton VT
    the light bump out for left and right fog light came on as soon as i turn on the car. I dont even have to turn on the fog's for that to come on. I'm hoping after i put the caps on this will all be fixed.
    Apr 14 2008
    Milton VT
    Quote Originally Posted by VZWalex View Post
    I dont know if the warning code eliminators will solve the issue of the fogs turning off and on.
    Oct 16 2008
    This is a freaking nightmarre !!
    I had to remove the bumper again yesterday to try something that Nick recommended. Same result. Good thing = I can pull and reinstall the bumper now in less than 20mn. The bad thing is the HID still don't Fu@&^ work! When plugged to the car harness = Nothing but they do work if connected to the battery directly
    May 20 2008
    2013 Passat TDI
    How do you have the kit hooked up? Is the ballast directly connected to the stock harness or are you using some kind of harness with a relay. If you have any kind of relay, you will get a bulb out warning. Try eliminating any kind of relay from your setup. That should solve the bulb out warning, and the cap will get rid of the flickering. Let me know if it worked out for ya.
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    Oct 16 2008
    Well, I have a problem here:
    If I start to dice the harness and at the end it still doesn't work, I am fucked
    I purchased this kit from Autobahn asking especifically if it was plug and play and was not throwing any code> The answer form them was YES !
    Apr 14 2008
    Milton VT
    stock fog light connector -- connected to -- connector (only one that fits, but upside down to make it work) -- that is connected to the ballast -- that is split into two wires ( which also have a fool proof connection, only one way to connect) -- which is attached to the hid bulb.
    The whole setup is pretty much fool proof in my opinion, each connector has a specific and one to connect too. When i contacted DDMtuning about this, they told me to flip over the connector that connects to the stock audi wire. I had to cut off some plastic tabs so it would work but this is the only way my bulbs light up. It was my own fault i didn't test this with the car on, as it worked just fine with the car off. I dont even know how to take the stupid bumper off so i had to do all of this by force in some cases. (left side i had to squeeze my hand into tight spots to find wires and on the right side i had to pull back the wheel well cover to access the back side of where the right fog light is located. I had a bitch of a time getting my under belly plastic pan out so that is why i had to go this route.
    It is quite a pain what im trying to accomplish with these hids but i think in the end it will be cool. halogen HID look alike bulbs just do any justice to the real thing in my opinion that is why i'm trying to get this to work.
    Apr 14 2008
    Milton VT
    could you take a pic of your setup laid out?....
    Oct 16 2008
    I will tonight
    Oct 16 2008
    OK, Here are the pictures:
    Assembled harness how it goes on the car
    Connector to car harness
    Yes the tab on the other side has been shaved
    WTF
    Apr 14 2008
    Milton VT
    ok, what i did is the same as you, i shaved off the tab of the last pic...but i also cut the little tab on the inside....this way you can put it on backwards to the stock fog connector on the car...if this doesn't work, my only other comment would be that the stock connector doesn't put enough juice....which makes no sense since mine puts out enough for the 55w kit. I would keep tying to get ahold of the company that sold it to you.
    Oct 16 2008
    Yeah, I think I have the same problem: I spoke with the wholeseller and they have a problem with a batch who has the power plug inverted. Rather than trim the inside of the connector, if you look closely inside where the contacta are, at the bottom of the contact, you can see a little square piece of plastic. With a small screwdriver, push this little square towards the outside of the connector and the wire will become free. Then, you just have to swap them and click them back in place.
    I can't try right now because the bumper is back in place, I'll do it this WE and will keep you posted
    Apr 14 2008
    Milton VT
    if you could....let me know how to get the bumper off....what a pain
    Jul 10 2008
    Austin, TX
    Oct 16 2008
    It's getting worse!!
    I finally figured out the wiring issue on the kit (wires were crossed) and now they power ON but blink like a turn signal. WTF
    Called the wholeseller (1 hr on hold) to get the anser: Problem comes from the car computer, you need "code canceller"
    Called Nick at Autobahn (he was not in the office today) and he does not understand why I need additional hardware since apparently, he sold a lot of the same kits than mine and never had any issue (beside the wiring). He will contact the Wholeseller next week to check what is going on.
    Bottom line, HID kit still in the box for a week now, removed the bumper 4 times ( I am getting good at it) and I am pissed !
