Results 1 to 17 of 17
    Jan 11 2007
    Salt Lake City, Utah
    So a tip engine can be used w/ a 6sp, but can a 6sp engine be used in a tip?
    And if so, what exactly needs to be done to do so? If it does work, I may have my engine sold
    ** GT2860R-7 S4 Build Log--
    LOOKING FOR:
    --Late 2.7t Block "BF"
    In Limbo Two Rings
    Apr 19 2008
    Utah
    Re: So a tip engine can be used w/ a 6sp, but can a 6sp engine be used in a tip?
    All of the 2.7 are Interaly Ballanced so yes you can swap them from auto to man to man to auto. I called you the other night to catch up with you give me a call soon i would love to show you the finished project. good luck on the motor
    Jan 11 2007
    Quote Originally Posted by Cobrakiller08 View Post
    Thanks buddy. Yeah I'll hit you back soon.
    I know they're internally balanced, but for example when running a tip engine in a 6-speed car there's an extra vaccum line or something that you have to bung. Do you need to add a line to the 6-speed motor or something when running a tip?
    LOOKING FOR:
    Veteran Member Three Rings b5s4tt's Avatar
    Mar 14 2007
    s4
    queens
    tip has sai whereas 6spd does not
    Jan 11 2007
    Expand on sai please and does said sai mean that a 6-sp can't be used in a tip car?
    LOOKING FOR:
    Veteran Member Three Rings joe dub's Avatar
    Sep 01 2008
    Illinois
    tip has a coolant line also if im not mistaken. there is a tranny cooler on the autos
    silver - RIP
    black - TAILS
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by joe dub View Post
    shouldn't have anything to do with the motor though, I would imagine all the small differences are fittings or Y pipes, not actual engine components
    - Clint
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    Quote Originally Posted by jibberjive View Post
    secondary air injection. It doesn't really do any thing as most of us B5 A4 guys just leave it unplugged. If I recall correctly, it is used to warm your cats up after start up.
    TEAM|AXION
    Active Member Four Rings 00s4slvr's Avatar
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    yup that secondary air injection is bullshit. All it does is makes your car sounds crappy on a cold start up and goes away after a min or 2.
    IMHO just a waste of space.
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    radiator is a bit different.. you have to open the holes in the 6speed one to accept the trans lines.
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Feb 29 2008
    Durham/NC/Southeast
    the SAI holes are blocked off in the 6 speed heads. This will mean that it isn't just a plug and play deal. Without new software or other mods the cel will be on for SAI low flow. Not that it can't achieved you just want to be sure the buyer is aware of the issues.
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    correct^^^
    "215 motoring" from the northeast swapped his 6speed to a tip. Send him a PM, I'm sure he coudl answer some question for you. IIRC he used a six speed motor.
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Aug 06 2008
    Canadia
    I can't see the SAI being an issue at all, the 6spd car dosn't have a SAI, therefore won't have the connections or the ability to detect that its not working.
    the B5 S4 is like the mafia... there is only one way out!
    Jan 11 2007
    Quote Originally Posted by MacDaddy View Post
    It's a 6-speed motor going into a tip car, not vice versa
    LOOKING FOR:
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    let me know how this comes out because i wanna do a manual tranny swap into my tip also.
    Aug 06 2008
    Canadia
    I've heard of people using a resistor in place of the pump, car thinks its working but it will save a code saying the warm up time is too long, but won't set off the CEL.
    at least thats what a guy at one shop told me.
    Jan 11 2007
    Quote Originally Posted by 00s4slvr View Post
    Little different idea here. As far as your tip motor is concerned, you just need to block off the secondary air injection holes. If you get serious about it I've got some info on part #'s and whatnot needed for the tip to 6speed swap as well. Feel free to email me when you for sure want to do it.
    Thanks for the info!
    LOOKING FOR:
