Results 1 to 7 of 7
Thread: help
    Veteran Member Three Rings evola4's Avatar
    Sep 03 2007
    05' Audi A4 Ultrasport
    henderson, nv
    help
    I started my car today and was in a real big hurry so I didn't let it warm up fully. Which I now wish I did. As soon as I left the parking lot and hit the gas the car felt like it missed. I noticed I was getting about 5lbs of boost not the normal 21lbs that I normally get. I got home and checked and it looks like all the lines are still attached and I vag'd it and it's not pulling any codes except 1 which told me I was running a little lean on bank 1. Anybody have any ideas?
    WTB K04 turbo ASAP
    http://etektuning.com
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Re: help
    how is your car acting in neutral?
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Sep 03 2007
    henderson, nv
    Re: help
    it's acting fine now because I unplugged the maf. If i put the maf back in then it will sputter all over the place.
    WTB K04 turbo ASAP
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: help
    Double check for a boost/vacuum leak. If none are found, replace the MAF.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Feb 17 2004
    Liberty Hill, TX
    Re: help
    that's a vac leak for sure, and has nothing to do with your lack of allowing the car to warm up before boosting
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Sep 03 2007
    henderson, nv
    Re: help
    Thanks guys I'm looking into it. I'll let you know. You still think it's a boost leak even if I unplug the maf and it starts to run fine.
    WTB K04 turbo ASAP
    Veteran Member Three Rings cdn20valve's Avatar
    Oct 09 2007
    B6 A4 Avant
    North Toronto
    Re: help
    Yes. Start the car, and while the engine is running, wiggle all visible vaccum hoses/lines. When the idle starts to dip you know you found the leaky hose.
