Results 1 to 31 of 31
    Veteran Member Four Rings maclem8223's Avatar
    Oct 16 2006
    04' A4 USP 1.8T QM
    RSM, California
    Immediate help requested
    Ok this just happened and I'm not near home I pulled up to a light cars idling real rough. I puuled over and changed cp's out thinking that was the culprit right away nothing...when I start the car it revs up to like two grand and eventually settles down to normal but it's still rough and only holding ten vac. MAF or something else...
    ~Matt~
    BetaAlphaTauMemeber #45
    USPMemeber #1001
    04' 1.8T Q6M 2871R Revo Tuned
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Re: Immediate help requested
    vac leak/bad maf...
    unplug your maf and see if it goes away
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Oct 16 2006
    04' A4 USP 1.8T QM
    RSM, California
    I'm thinking maf as well I'll check in a bit we came out for dinner might as well now especially since it's cold out
    ~Matt~
    USPMemeber #1001
    Jun 08 2008
    Calgary AB Canada
    Quote Originally Posted by aaaudiprotein View Post
    vac leak
    mhmm
    Saint Cloud, Fl
    yep
    instagram ------------> low_enforcement
    Oct 16 2006
    04' A4 USP 1.8T QM
    RSM, California
    A vac leak would make it rev up at start???
    ~Matt~
    USPMemeber #1001
    Oct 16 2006
    04' A4 USP 1.8T QM
    RSM, California
    On throttle I was still hitting full boost it was just hesitant
    ~Matt~
    USPMemeber #1001
    Jun 08 2008
    Calgary AB Canada
    when i had my vac leak my car would rev up and down from 1k to 2k
    Oct 16 2006
    04' A4 USP 1.8T QM
    RSM, California
    Quote Originally Posted by onceover View Post
    Constantly or just at startup
    ~Matt~
    USPMemeber #1001
    Jun 08 2008
    Calgary AB Canada
    mostly at stop lights when the engine was warmed up
    Oct 16 2006
    04' A4 USP 1.8T QM
    RSM, California
    Will it hurt it to drive home twenty thirty minutes
    ~Matt~
    USPMemeber #1001
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Not likely it is the MAF, especially if you are seeing -10 vacuum at idle. Most likely you blew the suction jet pump or some other type of vacuum/boost leak.
    Unplug your MAF and you will be able to drive the car.
    Oct 16 2006
    04' A4 USP 1.8T QM
    RSM, California
    That's what I wanted to hear
    ~Matt~
    USPMemeber #1001
    Oct 16 2006
    04' A4 USP 1.8T QM
    RSM, California
    Unplugged maf still running like crap.. Does it take awhile to adjust
    ~Matt~
    USPMemeber #1001
    May 24 2007
    Southern California
    Most likely a vaccum leak. I forgot a worm gear on my DV and the compressor side blew off and the idle was crap and would stall out.
    Quick easy fix.
    Kyle
    2.0L Revo GTRS Eliminator
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Definitely a vacuum leak. When I had forgot to plug the vac port on the Intake manifold, the car would "self" rev to 3500 RPM and then settle back down and then repeat!
    -Sami-
    Oct 16 2006
    04' A4 USP 1.8T QM
    RSM, California
    And that's exactly what it's doind. I didn't want to spend my Saturday working on the car besides the tranny mount; oh well it sounds like a great time to get rid of all those extra hoses and secondary air crap under the hood. Either way thanks everyone for your help; she made it home and it is definitely a vac leak the hunt will begin tomorrow.
    ~Matt~
    USPMemeber #1001
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    first, look at those check valves, they brake a lot.
    Veteran Member Four Rings quat's Avatar
    Apr 06 2007
    A4 Quattro 1.8T, H-D VRSCA
    Pittsburgh
    mine has a vacuum on -10 and it doesn't do any of that
    -Ryan
    2002 1.8t Quattro
    Nov 19 2007
    Anonymous
    Same situation happened to me last year. Turned out it was a suction jet pump. Dealer replaced under warranty.....
    Oct 16 2006
    04' A4 USP 1.8T QM
    RSM, California
    Quote Originally Posted by quat View Post
    It should hold -20 at idle.
    ~Matt~
    USPMemeber #1001
    Feb 19 2007
    Charleston, SC
    I pull a solid 22inHG at idle and about 24-26inHg on decel.....
    -Sami-
    Oct 16 2006
    04' A4 USP 1.8T QM
    RSM, California
    Yeah it should definitely be holding more than -10
    ~Matt~
    USPMemeber #1001
    Oct 16 2006
    04' A4 USP 1.8T QM
    RSM, California
    I can't find any leaks this is annoying anyone with experience with locating leaks want to call me and point me to some trouble spots I'm all ears 812-604-5650
    ~Matt~
    USPMemeber #1001
    Oct 16 2006
    04' A4 USP 1.8T QM
    RSM, California
    No throttle response either
    ~Matt~
    USPMemeber #1001
    Jun 08 2008
    Calgary AB Canada
    i doubt its the same problem i had, but out of curiousity try to take off the oil filler cap while the engine is running, if theres loads of suction you may be in luck
    Veteran Member Four Rings Raus's Avatar
    Aug 18 2005
    B6 1.8TQM, Mk2 GTI
    I had the #11 valve break apart on me once
    A second time one of the intercooler hoses popped off. Both times, I had no vaccuum/boost, car ran very rough with barely any throttle response. It stalled pretty much everytime I let off the throttle but idle never jumped up and down like you guys described.
    Ich bin der Musikant mit Taschenrechner in der Hand
    Oct 16 2006
    04' A4 USP 1.8T QM
    RSM, California
    So there is NO leaks...tennis ball method visually inspected each hose, and pretty much took the vac system out and back in trying to find it. I'm down to probably a suction jet pump or another type of valve which your not going to tell from a boost leak. I'm going to drink some beer; I'm done for the day...it won't fix the car but I'll sure as hell feel better.
    ~Matt~
    USPMemeber #1001
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Beer FTW!
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Oct 16 2006
    04' A4 USP 1.8T QM
    RSM, California
    So, after reading these three threads severeal times and finding NO leaks in the actual lines...I'm hoping removing all this crap can't hurt. any thoughts...
    http://www.audizine.com/forum/showthread.php?t=235106
    http://www.audizine.com/forum/showth...hlight=in-line
    http://www.audizine.com/forum/showth...ight=n112+n249
    ~Matt~
    USPMemeber #1001
    Oct 16 2006
    04' A4 USP 1.8T QM
    RSM, California
    No one...any other thoughts on what the problem could be or is everyone convinced it is something to do with a vaccum or boost leak?
    ~Matt~
    USPMemeber #1001
