Results 1 to 18 of 18
Thread: No power at 5K
    Jul 26 2008
    Jersey
    No power at 5K
    Well I just recently got my car back from the body shop - and tonight I got on it hard for the first time.
    Here's the facts:
    The car has been sitting for 2.5 months - it's been started to get moved around the shop - but never driven.
    The car was hit in the rear, and the gas tank was slightly dented, but it popped back out.
    Here's whats happening:
    Under full throttle (only tried 2nd and 3rd gears) at what seems exactly 5,000RPM the car just completely cuts out. It's like I'm not even hitting the gas.
    It doesn't break up at all really, just stops accelerating. It does not stall.
    I looked in my rearview and noticed some smoke (black).
    I'm thinking either 1, my plugs are fouled - but why wouldn't the car break up and run like crap after 5k?
    or 2, there is damaged to the fuel pump, the ECU is sensing not enough fuel and cutting the throttle to prevent damage?? (if thats even possible).
    My car is a stage 3 car btw.
    Jul 26 2008
    Jersey
    Re: No power at 5K
    and I have a TCD installed
    Sep 21 2008
    Toronto, Canada
    Re: No power at 5K
    your vtec is broken?
    Jul 26 2008
    Jersey
    Re: No power at 5K
    The only faults I have are from my rear O2's not being there and vehicle speed sensor.
    Could that be it?
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    Re: No power at 5K
    valet mode? i konw that cuts off at 5k, but also doesnt allow boost.. my .02
    these cars are frustrating
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Feb 29 2008
    Durham/NC/Southeast
    Re: No power at 5K
    Quote Originally Posted by spinny View Post
    Could that be it?
    there is a second rev limiter at 5k when there is a speed sensor fault.
    Get rid of the code and you will be fine.
    Jul 26 2008
    Jersey
    Re: No power at 5K
    That sucks. I wonder how the speed sensor went bad. The car has been sitting for 2 months. Is there any wiring going to the rear passenger side for the sensor?
    Feb 29 2008
    Durham/NC/Southeast
    Re: No power at 5K
    the speed sensor in on the driver's side of the trans. Right by the axle. I have seen mice, rats and squirrels eat wiring on cars sitting at shops before. I would start by checking the connector/wiring on the sensor.
    Jul 26 2008
    Jersey
    Re: No power at 5K
    Quote Originally Posted by Evan@Absolute View Post
    Ok I'll double check it. Is it possible to get at it without removing the down pipe?
    Feb 29 2008
    Durham/NC/Southeast
    Re: No power at 5K
    sure. Not saying it is fun but you can get there from the bottom reaching up behind the driver's side inner cv joint.
    Jul 26 2008
    Jersey
    Re: No power at 5K
    I wish I could just disable the sensor. I did notice the car is a little jerky under part throttle and when I let up on the throttle.
    Active Member Two Rings quattroSD's Avatar
    Nov 03 2007
    B5 S4
    San Diego
    Re: No power at 5K
    Quote Originally Posted by kbjy11 View Post
    LOL!
    oh man, that's great.
    C. Murphy
    Drive Fast, Take Chances
    Veteran Member Three Rings rouellettea4's Avatar
    Apr 07 2005
    00S4STG3, 1995 Subaru Impreza, 96 A6 (blown HG)
    Holden/Worcester, MA
    Re: No power at 5K
    Here's the facts:
    Don't you have a launch control setup? If the wires get crossed, it'll almost blast you through the windshield when you hit the limiter. When I was experimenting with the install that occurred haha. Make sure you get it fixed before the battle with the M3.
    Jul 26 2008
    Jersey
    Re: No power at 5K
    Quote Originally Posted by rouellettea4 View Post
    No launch control.
    Veteran Member Four Rings awd2ks4's Avatar
    Aug 24 2008
    2000 S4, Blown LS2 240sx hatch, LS3 240sx vert, 02 wrx
    Santa cruz
    Re: No power at 5K
    How does it almost blast you through the windsheild? have you launched the wot box yet? VIDEO.........
    Jul 26 2008
    Jersey
    Re: No power at 5K
    hmm I forgot to update this post!
    My central locking pump is messed up, and it was killing the VSS signal to the ECU.
    Active Member One Ring taemanawras's Avatar
    Mar 06 2016
    utah salt lake city
    how did u fix it
    Established Member Two Rings I-Reef's Avatar
    Aug 20 2012
    11 335i
    Henderson, NV
    You know this is like 7 years old o.o.
