Results 1 to 12 of 12
Thread: Water/meth kit
    Established Member Two Rings lask8ter134's Avatar
    Sep 07 2007
    Audi A4 B7
    Whittier,CA
    Water/meth kit
    I'm thinking about getting this but will it work on the APR 91, 93 or race file make this work? Thanks-Rob
    Audi A4 Non-Sline 2.0T Fwd Cvt Evo Ms Intake/Apr 91/100/Miltek 200 Cell Cat/Magnaflow Exhaust/Vogtland 35mm springs, Koni Sport Shocks/R8's Replicas w Toyo Proxy 4's/Hawk Ceramic Pads/Front Filler Plate/30% tint/Garmin 760 GPS
    Veteran Member Four Rings eastwick897's Avatar
    Jun 26 2008
    New Jersey
    Re: Water/meth kit
    it'll work on all of them but it will probably work the best on apr 100 i'm not positive so don't take my word because I don't know what timing apr 100 pulls. I'm sure other people will chime in.
    B7 A4.... 394awhp
    Veteran Member Three Rings CX-7&A4's Avatar
    Dec 09 2007
    CX-7 AWD/A4
    Foreclosure Captial of the US
    Re: Water/meth kit
    50/50 will work with anything.
    07 Mazda CX-7 AWD
    06 Audi A4 Fail2Trak CVT - TRW Front/Mintex Redbox Rear
    DUH! an Audi
    los angeles, CA
    Re: Water/meth kit
    rob, you really in the mod spirit performance wise, I love it. I cant help you cause I only know revo.
    Senior Member Two Rings ringofsteel's Avatar
    May 05 2008
    67 BETTLE,95 GOLF JOKER, B7 A4
    BODENSEE, GERMANY
    Re: Water/meth kit
    DO IT! I have the VAST PERFORMANCE w/m kit and I use my 100 APR. I can run my 93 too. I have 95 ron or 98 octane here and I put it in and run 100 program. I love the w/m, I use HEET with a 50/50 of water a 1:1 ratio. I also use -20F windshield washer with "methanol" in it straight out jug. Runs fine. Also there are alot of kits, Snow,Devils own, Vast performance, and others I am sure. Again I checked into them all by I liked the service I received from VAST. Their kit went in in hour by myself( And I am not really skilled) here is my small write up not very good and a couple of picks. VAST made a custom piece for my nozel, free of charge, now it is a kit on their site. http://edition719.com/smf/index.php/topic,103762.0.html I can say my pulls are more consistent, and and harder, and I love the way it pulls all the way through RPM"S Well good luck with your choice. I am sure others will chime in on it too.
    Veteran Member Four Rings Grishbok's Avatar
    Apr 15 2008
    Reston
    Re: Water/meth kit
    to maintain the most consistant flow and octane rating through the combustion process, i would use the snow performance kit that piggy backs on the maf signal. Keep in mind that water methanol burns with a 116 octane rating, so by using it, you are altering the octane rating of the mixture.
    2008 A4 Quattro Brilliant Black
    *SOLD*
    StreetTunedTV.com
    You are violating the 3 rules of forum posting.
    1. Title thread appropriately
    2. Use the search first
    3. If you didnt find what you were looking for, its because someone else didnt follow #1.
    May 05 2008
    BODENSEE, GERMANY
    Re: Water/meth kit
    true, what I like about VAST and Devils Own is it comes with a switch which you tune when you want it to start to spray 40-60% and when you want max spray 100%. This kit also use the the same sensor, so that when the turbo is not under load it doesnt spray, and when it does in is spayed at the amount you want. This way based off mods or when you want meth it is there, plus the switch shows when there is power, power to pump and when the pump is spraying, on top of you set it using how ans a what PSI of BOOST you want it. It is pretty much plug and play but then you can tune it specific. Good luck!
    Jun 26 2008
    New Jersey
    Re: Water/meth kit
    If you do it you'll love it>
    B7 A4.... 394awhp
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    Re: Water/meth kit
    ive only heard good things so far.
    eastwick, did you get that gsg cai yet?
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Jun 26 2008
    New Jersey
    Re: Water/meth kit
    ^^^not yet its on back order so as soon as I get it if you still want the TIP just let me no
    B7 A4.... 394awhp
    Mar 19 2008
    Re: Water/meth kit
    ya i still want it. AEM came out with a CAI with a polished pipe as well tho.
    http://www.namotorsports.net/detail....t_cd/AE21-681P
    i might get that as it is tempting but i already have the filter so who knows
    2019 S5 BO.SS
    2009 R8 6 Volt :)
    Veteran Member Four Rings Geoffafa's Avatar
    Aug 31 2007
    The Big Blue Bitch and her mess
    Miami
    Re: Water/meth kit
    i had apr 100, with my water injection, never used meth, always used pump gas, never had any problems with timing, just the fuel issue, which is unrelated, i think
    F.T.W.L.T.B.D.W.I.C.T.W.
    IG | @fukn_fafa
    So air is like the hot girl that is no fun in the sack, and good coils is the cute girl that is crazy in the sack. -chrislane
