Results 1 to 12 of 12
    Veteran Member Three Rings Mister2's Avatar
    Jun 30 2007
    Virginia Beach
    driveshaft vibration problem
    I'm having an issue with my drive shaft. The noise and vibration is coming from the rear end, sounds like under the rear seat area. It sounds like something has come loose and its touching the drive shaft. The noise/vibration happens whether its in gear or not, as long as I push the gas it will start up. But as long as there is no load on the drive shaft its silent. It started doing it a few weeks ago, mostly noticed it only if I made a sharp turn to the left or if it was raining. But over the past 3 days it's gotten significantly worse and its pretty loud. Almost sounds like the u-joint is hitting something solid.
    Has any one had a problem like this? Any help would be greatly appreciated! I'll try to keep an eye on this thread and answer any questions. My friend has offered to let me use his garage this weekend while I'm off work so hopefully I can get this resolved.
    I tried a search and didn't come up with anything, I was told it was probably the u joint so that's what I've been focusing on.
    99.5 A4 1.8TQM
    APR Boost Guage - Forge 007 DV - Techtonics 2.5" Exhaust - 17" RS4 Rep's - Debadged - APR 91/100 - 034 Motorsport 3" Test Pipe
    Working my way towards a BAT
    Ich liebe mein Audi
    "...oh so you got VTEC huh? That's cute, so does my girlfriends car." - Me
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    Re: driveshaft vibration problem
    have you recently had the trans out, or done a tailshaft seal. if so, the driveshaft may be misaligned, throwing it out of balance.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Jun 30 2007
    Virginia Beach
    no, the only tranny work i had done was when i had my new clutch put in, and that was last winter if i remember correctly.
    99.5 A4 1.8TQM
    Ich liebe mein Audi
    Veteran Member Three Rings bikerbob951's Avatar
    Jul 25 2008
    2006 Volvo XC70 AWD, 1936 Dodge D2 Touring Sedan
    Cincinnati, OH
    bump, cause he needs it
    Vorsprung Durch Technik.
    1999 AEB B5 A4 quattro
    My new build thread. Instagram
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    For starters we don't use U-Joints. We have a CV-Joint at both ends of the driveshaft. I found out first hand what happens if a bolt isn't tightened down and falls out, or for some odd reason somebody loses a driveshaft flange bolt.
    This will cause a serious vibration and noise before 35mph, and you won't even think about driving the car until the problem is fixed, so it makes me think that's not the issue in this case.
    Have you checked the splash guards that run under the driveshaft? I've seen a couple times where a customer had some issues with that rubbing after hitting a large puddle or pile of snow.
    Does it seem like there's a lot of play or slop in the rear upon acceleration? It's possible you have a junk bushing/mount at the front of the differential. That would probably be more pronounced as a clunk when going from accel to decel, or on engine braking.
    Veteran Member Four Rings J Ozzie's Avatar
    Jun 06 2008
    Port Moody, Canada
    ive had that sound as well but its only after hitting a puddle or deep slush...
    2014 Audi Q5 TDI - Brilliant Black | LED Fogs | VCDS Mods | LED Interior swap |
    R.I.P... (wrecked)2005 Audi A4 1.8TQM 6Speed
    R.I.P..2001 Audi a4 1.8TQM (casa white no sunroof)
    Vancouver Audi Club.ca
    where's our resident intoxicated lobster Canadian - Thomas
    Apr 22 2007
    Riverbank, Ca
    Quote Originally Posted by djwimbo View Post
    For starters we don't use U-Joints. We have a CV-Joint at both ends of the driveshaft. .
    And we have a U joint (or whatever that thing is) in the middle of the drive shaft halfs...
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by andyrew View Post
    ok, true, but the likelihood of that being a failure point is very very low. Given that the noise is coming from the rear, I wanted to clarify that there wasn't a U-joint back there.
    But yes, you are correct, there is one U-Joint in there. It's there so that the driveshaft has more flex(angle from driveline "slop") and is easier to remove.
    Nov 21 2006
    san francisco, ca
    It could be a diff mount gone bad.
    --dillon
    1998.5 A4 2.0TQM ADR/058, Custom ME5 tune by 034, ABA 92.8 stroke forged crank, Scat rods, JE Pistons (83mm/8.5:1), Schrick cams, Supertech springs and retainers, inconel exhaust valves (+1mm), Spa T3 mani with a Precision 5557E-B, 034 3inch exhaust, etc, etc, etc. 034 featured user
    2012 S4 Prestige, Titanium, Monsoon gray metallic, DSG. 034 ECU and TCU tunes and other bits.
    May 22 2008
    St Clair Shores, MI
    Are you sure it's not the exhaust rattling around?
    13 S4 Monsoon Gray - 6MT l sports diff l Nappa l Atlas l EPL Stg2
    DP l MercRacing HX l iAbed TB l Sach's Xtend l AWE Track/Touring w/ res DPs l 034 Xbrace & drivetrain mounts l P3 Track
    Jun 30 2007
    Virginia Beach
    I didn't really get a chance to check much. I got under the car but wasnt able to see much because I couldn't get it high enough. The jack even broke. Nothing really jumped out at me as being obviously broken. I don't see how I could inspect much of it without completely dropping the exhaust and removing the heat shield above it. The rear doesn't really seem to have any slop, or any more than normal.
    99.5 A4 1.8TQM
    Ich liebe mein Audi
    Jun 30 2007
    Virginia Beach
    Quote Originally Posted by SpoolinPelican View Post
    I know its not that because my exhaust is rattling and its a different sound all together. I did however find out where the exhaust is hitting. The sound I'm more worried about is much louder and directly related to RPM's
    99.5 A4 1.8TQM
    Ich liebe mein Audi
