    Nov 12 2007
    toronto, ontario , canada
    T3 High Flow_cat???
    well i got a t3 setup on my a4 one lil probalem, where do i put my high flow cat, and what brand should i use, since the stock cat got replaced with a test pipe, what makes more power, downpipe first then cat or cat then downpipe coming from the turbo.
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: T3 High Flow_cat???
    why do you need one?
    - Clint
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    you would make most hp running Test Pipe into Down Pipe, but most catalysts are placed close to the turbo, to aid in warmup. subaru's come with an oem up pipe with a catalytic converter upstream of the turbo. as you would assume, they run into the problem of the shit flaking off and hitting the turbine at full boost.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Nov 12 2007
    cuz of where i live, we do emission test every 2 years, plus when i ran a test pipe on my k04 setup my car used to shoot out alot of smoke from my exhaust.
    Senior Member Two Rings slideitsidewayz's Avatar
    Jun 30 2008
    1998 Audi A4 1.8tqm gt2871r
    North Jersey
    the test pipe makes more power hands down. its something like 10-15hp increase for k03 and 30-40hp increase for big turbo apps...thats what i read off ot the atp test pipe atleast and thats what im running. it should go turbo, cat/test pipe, down pipe, exhaust.
