Results 1 to 15 of 15
    Senior Member Three Rings FourRingsB6's Avatar
    Oct 07 2008
    2005 A4(HIS), 1999 Jetta(HERS)
    Lancaster, PA
    Quick Brake Question
    I'm doing the 3.0 brake upgrade on my car and I just found a deal on a set of carriers. My question is, did the USP's use different brakes at all or are they the same as the standard 3.0? The carriers I'm looking at are off of a totalled USP. Thanks.
    Stretched, poked, and slammed.
    Veteran Member Three Rings B6480Avant's Avatar
    Jul 11 2008
    B6 A4 Avant
    Gilbert AZ
    Re: Quick Brake Question
    usp is just cosmetic upgrades
    Oct 07 2008
    Lancaster, PA
    Thats what I figured, but I just wanted to be 100% before I ordered the wrong parts. Thanks
    Veteran Member Four Rings AudiOso's Avatar
    Aug 04 2007
    Do Hotwheels count?
    Boardman, OH
    So what's the breakdown on brakes? (no pun intended) B7 2.0 carriers along with the bigger rotors and dust shields give you more swept area. What about the carriers from a B7 3.2? Do they work with the calipers from the 1.8 B6 cars? I'm looking for an affordable brake upgrade.
    This is a commuter car so I don't see the economy of spending big bucks on brakes, but I hate the stock brakes on my Avant. Especially after I've driven my TT or my S4.
    A couple of Audi's later...
    "It's a false state of elation... You can join the Prozac nation... If you want to..." - Killing Joke
    Aug 01 2008
    04 A4 1.8t USP
    SE wisconsin
    If you can find stock b7 brakes used, that would be the best bang for few bucks. 320mmF 288mmR rotors, and the calipers are much larger too.
    Aug 08 2007
    A4, GTI, Corrado
    Jacksonville, FL
    The 3.0 already has the same size brakes as the b7's.
    And no the USP doesn't have bigger brakes.
    2011 VW Jetta TDI
    2002 Audi TT Quattro
    2002 VW Jetta 1.8t
    1993 VW Corrado SLC
    Established Member Two Rings Plasticar's Avatar
    Jul 08 2008
    B6 A4Avant, B5.5 Passat 4mot
    West Bloomfield, MI
    If you don't want to spend big bucks, just buy better pads when you get around to the next brake job. Better pads can make a huge difference. Of course this opens a can of worms from everyone what the best pads are.
    Oct 07 2008
    Lancaster, PA
    I'm buying better pads as well (PBR Ultimate Ceramics) but I just picked up the carriers for $40 bucks so I figured I might as well go to 312 considering the front rotors are pretty well grooved. Thanks again for the help guys.
    Veteran Member Four Rings forevraudi's Avatar
    Sep 01 2008
    San Diego, CA
    ecs tuning has a oem big brake 3.0 conversion kit, i dont know if it is overpriced though
    Buncha motorcycles
    Memphis, TN
    Way overpriced
    APR Stage 2/AWE Intake
    Oct 07 2008
    Lancaster, PA
    Put it this way... There cheapest setup is $429 w/o pads. I'm paying $220 with $75 pads. Not to knock ecs because I've bought a lot from them in the past but that kit is way over priced.
    Aug 26 2005
    A caliper stiffening kit makes a big improvment in the stock setup also, for $100 or less, for a DIY setup. I used a 1/2" shoulder bolt, and a bronze bushing sized on the OD, to replace the rubber caliber guide bushings. The improvment in the responsiveness of the stock brakes is amazing.
    Veteran Member Four Rings JMRQuattro's Avatar
    Jul 04 2008
    Seattle, Washington
    ^^ sorry temporary thread jack. Hey john what time tomorrow should i plan on?
    - Justin -
    Veteran Member Four Rings redlabel81's Avatar
    Nov 24 2007
    A4 1.8TQ 2005.5 + A6 1.8T 1998
    Tromsoe, Norway
    Quote Originally Posted by KJIV View Post
    No it doesn`t. B7 have 320mmX30mm 3.0L has 312mmX25mm. Rear is 288 on b7 compared to B6 3.0L 255. :)
    Life is too short to drive ugly cars!
    Phantom Black B7 A4 1.8TQ Avant
    //BSR PPC stg 1, 98 Oct//BSR cat back//S-line front rebuild//S-line suspension//Supersport loweringcaps//Votex valence//S4 doorblades//RS4 mirrors//S-line roofspoiler//S-line door sills//LED interior//Hoen fogs//mTec 6000k HID//RNS-E//S4 grill//MMR HR4//H&R 8mm//Dectane HL//LED licenseplight//Euro RS4 steering wheel//Sonniboy "Tint"//RS4 rear sway//
    Apr 13 2009
    2002 A4 3.0Q tiptronic
    Peru, MA
    I just bought a set of rear rotors for my 3.0, they're 255mm and thats the larger size offered stock.
