Results 1 to 27 of 27
    Veteran Member Four Rings JBM's Avatar
    NorFOLK, VA
    If I get the Cat CEL does the dealer need to reset the Readiness or Can I?
    I'm going to install my HFC and I was wondering if the I can do all the programming with VAG that I need to?
    thanks
    "Give a Man a Fish, Feed Him For a Day. Teach a Man to Fish, Feed Him For a Lifetime"
    '02 B6 1.8T, UnitedMotorsport Tuned FrankTurbo L21, 550CC, 3" MAF, BB Intercooler, 007, 034 HFC, Neuspeed Exhaust, B5 S4 Brakes, KW Suspension, S4 Recaro, and the list goes on.
    Veteran Member Four Rings gdawg'05a4's Avatar
    May 03 2005
    '17 Q7, '95 Audi 90 AAN Swap
    Boston
    Re: If I get the Cat CEL does the dealer need to reset the Readiness or Can I?
    IIRC the readiness code gets reset after a few start/stop cycles or a certain amount of miles. I *don't* think you can do it via VAG.
    '17 Q7 3.0T | Graphite Gray | Rock Gray || Prestige | Cold Weather | Tow
    '14 A6 3.0T | Daytona Gray | Black || Prestige | Cold Weather | Driver Assist | Rear Sunshades | 19" Sport
    EPL S2 + TCU
    '95 90 Quattro Sport MT5 | Pearl | Black || 20vT AAN swap
    Previous Cars:
    '12 S4 | '13 Q5 2.0T | '11 A4 2.0TQ | '07 A4 2.0TQ | '06 S4 25quattro | '05 A4 1.8TQ MT6
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by gdawg'05a4 View Post
    I'm pretty sure it resets when you clear the engine controller via VAG-Com (Ie: clear the MIL code) because that resets everything including long-term fuel trims.
    Why would you get a CEL or fail readiness from a HFC? I don't get 'em and I run a HFC. My O2 readiness checks are 'good' (Except today since my primary O2 died. I'll have that fixed early next week.).
    In MD I also thought you can have one readiness check fail and the remainder (7?) pass and still pass state inspection.
    -Doug
    May 03 2005
    Boston
    I thought that as well but when I cleared a CEL on my car, the readiness was just blank, did not say "OK" (or ready, whatever it uses to indicate its good to go). Unless I missed a step somewhere. A few people have tried to clear CELs via VAG and then go to the inspection station right after but the computer caught the readiness was not "OK".
    EPL S2 + TCU
    Previous Cars:
    May 03 2005
    Boston
    EPL S2 + TCU
    Previous Cars:
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    You can easily reset readiness with the VAG-COM (provided the hardware is correct)
    Basically you first have to clear all of the codes...once this is done you will go into group 4
    Throttle Body Adaptation: 04, block 060
    O2 sensors: 04, block 034 (hold foot on brake, then depress gas pedal to floor)
    Cat: 04, block 046 (hold foot on brake, then depress gas pedal to floor)
    Evap: 04, block 071
    Leak detection: 04, block 070
    Secondary Air Injection: 04, block 077
    Recheck Readiness 15
    Feel free to rep me if you would like j/k You guys may want to sticky this in the DIY forum.
    May 03 2005
    Boston
    Yep, there are the 6 readiness components. Cool, did not know that.
    EPL S2 + TCU
    Previous Cars:
    NorFOLK, VA
    so when I go into group four what do I do? Just that procedure or what? Thanks
    _jared
    Veteran Member Four Rings heateris's Avatar
    Aug 16 2004
    08 A4 2.0TQM6 ~ 08 Highlander Sport
    SE PA
    i think he's replacing his bad OEM cat with a HFC.
    NorFOLK, VA
    yup...I have about 96K and the cat went out. VA is giving me issues left and right for it and so I went with the 034 HFC but I'm seriously down to the last minute in getting this installed and tested...btw
    anybody have instructions for installing it.
    Veteran Member Four Rings JMRQuattro's Avatar
    Jul 04 2008
    Seattle, Washington
    Get a TP and anti fouler it. Worked for me. But thank you 400hpa4 for that procedure, that's nice to know i don't have to drive around for days every time i get a code reset. That really should be made into a sticky for future reference.
    - Justin -
    Aug 16 2004
    SE PA
    Quote Originally Posted by JBM View Post
    3 bolts on top and 3 bolts on bottom. unplug your o2 sensors by the coolant resivor and remove. swap the o2 sensors to the HFC and reinstall. the botton bolts are a little tricky. extenstions, swivel, and extra hands help.
    Jul 04 2008
    Seattle, Washington
    Quote Originally Posted by heateris View Post
    I thought i read somewhere in a DIY that you actually had to get under the car and remove the pipe that the cat/tp attaches to on the opposite side of the turbo as well.
    - Justin -
    NorFOLK, VA
    okay yeah I was looking at the cat in the wrong direction. I had the exhaust side going towards the turbo so I was like uhhh wtf...I have to do this without a lift but I'm thinking I'm going to unbolt the DP of my neuspeed and pull it out and attach it that way...I hate this...I have to do emissions and the sniffer will pick it up if I ran a TP
    Jul 04 2008
    Seattle, Washington
    they actually do the exhaust test in your area? Mine was just standard OBD II. So the anti fouler worked.
    - Justin -
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by SeatownB6 View Post
    Virginia are a bunch of sticklers. They are a PITA from DMV up to DOT. Deep down south in VA you might be able to get away with it but not up near DC.
    I actually thought JBM was registered in MD. I thought MD is cheaper than Fairfax county VA.
    -Doug
    Jul 04 2008
    Seattle, Washington
    That sucks, how do people get away with it then? Swap out the test pipe for a cat before testing? Seems like the only reasonable solution.
    - Justin -
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    _jared
    Open up VAG-COM
    Go into engine, read the codes and clear them, you must resolve any codes before adaptation, so you may need to fix stuff.
    In the engine portion, you will see group 4, newer versions of VCDS will guide you through it.
    There will be three measuring blocks, you can only do one block at a time, I am flying to Newark right now so I cannot post up screen shots.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Newark?
    EDIT: nevermind. read the regional forums.
    -Doug
    Aug 16 2004
    SE PA
    ya, you'll need to get under the car to get at the bottom bolts. i pulled the cat out thru the top of the engine bay.
    NorFOLK, VA
    yeah I don't know how these germans think of engineering this crap...I have to find all my tools first since my mother "cleaned" the garage. She just threw crap around and said tada...anyways I sprayed them down with pblaster and let them sit...
    As for the MD/VA thing. I live in VA but I go to school at Annapolis so I need to get my car taken car of in VA. Its stupid because two counties down they don't have emissions. Its just another way the state can bring in money. Let me tell you about stupid safety and front plates...fck that...
    NorFOLK, VA
    So apparently all the shops around here do not install customer parts because of some VA law...wtf...also I have no help b/c no family or friends around and to top it off I have gorilla hands..
    so can I
    1)unbolt the cat
    2)drop the back part of the exhaust
    3)unbolt the dp (cut the fcking bolts off)
    4) pull the cat/dp up through the top w/ the 02 sensors
    5) put the 02 sensors in the new HFC
    6) drop the HFC down back
    7) bolt the HFC back into place
    8) bolt the DP back to the exhaust back up
    9) bolt exhaust back up
    10) clear codes and drive into the sunset
    Aug 16 2004
    SE PA
    so can I
    1)unbolt the cat
    sounds like you got it under control. we left the DP in the car and just removed the cat.
    NorFOLK, VA
    Ok, so I got the new 034 cat in. Problem now is that I have P0420 low efficency. I really need to get this shit worked out with my car, because I'm a month over due for emissions. I took it to Audi dealership and they said it was my cat, so I replaced that and I'm still having the problem. Do I need to get anti foulers or what?
    This is driving me insane.
    Aug 16 2004
    SE PA
    did you clear any codes when you installed the cat?
    NorFOLK, VA
    I didn't install it RAI did and all the codes were gone, but the readiness was not set. I'm going to throw a fouler in there for good measure tomorrow morning, but I'm getting tired of this shit...
    NorFOLK, VA
    Alright so I got a problem. RAI decided to hercules the O2 sensors on or put thread lock because I cannot get the front one or the back one off. Just wondering do they thread the opposite direction of regular bolts/threads?
