    Oct 30 2008
    2005.5 Audi A4 Avant
    Grand Rapids,MI
    Stock Spark plug gap
    Can anyone tell me what the stock spark plug gap is on a 2.0t? Thanks
    Veteran Member Four Rings Grishbok's Avatar
    Apr 15 2008
    Reston
    Re: Stock Spark plug gap
    stock spark plugs should be .032
    If you are chipped , you should run .028
    2008 A4 Quattro Brilliant Black
    *SOLD*
    StreetTunedTV.com
    You are violating the 3 rules of forum posting.
    1. Title thread appropriately
    2. Use the search first
    3. If you didnt find what you were looking for, its because someone else didnt follow #1.
    Veteran Member Three Rings barkerd427's Avatar
    Oct 04 2006
    2007 Audi A4 & a honda
    Princeton, NC
    It is .028 inch. You could have found it on Autozone.com
    2007 A4 2.0T S-Line Quattro / Deep Sea Blue / Black Leather Interior / Nav / Heated front seats / Xenon head lamps / APR Snub Mount / RS4 Pedal Set / RS4 brushed aluminum grille / RS4 rear sway bar / RS4 parking brake handle / Xenon match interior lighting / SOON Custom fog light grilles with S6 LEDs and RS4 mesh and brushed aluminum trim, just need to find the trim
    Established Member Two Rings snackbarber's Avatar
    Jan 03 2009
    2001.5 S4 brilliant black, 2006 B7 A4 Ocean Blue Metallic Stage 2+
    Hood River, OR
    .032? I am having some misfire trouble(after replacing all coil packs). Under load if I accelerate it will throw misfire codes(on random cylinders). I decided to pull the plugs and inspect. It appears the plugs I have are NGK PFR6U-11G(I was expecting a Bosch part). So far cylinder 1 and 2 have .042 gap, and cylinder 3 has .044. Do these plugs just need to be regapped or is this some odd OEM plug? When I do a google search for these plugs they seem to come back as compatible with A4 V6(no mention of 2.0t like I have). Advice? Oh and my local NAPA says they don't have any plugs for my car in stock.
    B5 S4 \\\ JHM DTS | SSAC non-res twin two turbo back | J-Fonz Stage 2 or NotoriousVR w/no egt or o2 | STE PPD
    B7 A4 \\\ GIAC stage 2+ | APR HPFP | AWE FMIC | HPFP 145 Bar PRV | Stasis exhaust | 034 HFC | Bilstein PSS9 | Gunmetal VMR v701 | RS4 rear sway | BSH Stage 2 PCV
    Veteran Member Three Rings TheHeggi's Avatar
    Aug 03 2008
    05.5 2.0t A4 + 02 CBR600 F4i
    Redlands, CA
    Quote Originally Posted by Grishbok View Post
    Wrong sir, the set of spark plugs I bought directly from the dealership were pre-gapped at .028
    05.5 DG 2.0TM FWD
    [Stasis SS][RS4 Rear Sway][APR 91][AEM intake][034 HFC][podi/stepper boost gauge][Satin Black B6 USPs][S-Line front bumper][RS4 Grille][Satin Black S4 blades][DIY Ti vinyl][DEPO projectors w/6000k]
