Results 1 to 34 of 34
    Active Member Three Rings AP-Specialties's Avatar
    Mar 15 2008
    A few Audis
    Independence, MN
    Exclamation Parting out: 1997 Europa Blue A4 1.8T Quattro 5 speed
    We continue to bring in inventory to provide you with a wide range of available used B5 A4 parts...This one almost got brought back to life for the road, but now has plans to become another A&P Track Car...At least the shell.
    Please check out our feedback posts here:
    http://www.audizine.com/forum/showthread.php?t=130524
    http://www.audizine.com/forum/showthread.php?t=248038
    http://www.audizine.com/forum/showthread.php?t=198448
    Oh and you can even read this negative thread about us:
    http://www.audizine.com/forum/showthread.php?t=252611
    Now on to the goodies:
    We have just received in a new parts car! It is a 1997 A4 1.8T Quattro with a 5 speed manual transmission in Europa Blue. The car has 137,901 miles on it. We were able to start, run, and drive the car around--the engine runs great, brakes are no good, suspension is intact, and the transmission shifts nicely. However, after inspecting the car, the following items were found to be damaged, faulty, or untestable--
    -ABS Module & front calipers
    -Radio Surround
    -No center arm rest
    Note that we have most of these parts available in our regular inventory, so if you're looking for one, browse our eBay store or shoot us a PM or email at [email protected].
    On to the price list! Note, we have almost 900 A4 parts listed online here, this is just a small summary of the parts we can and will sell! If you see it, we sell it!
    Buyer pays shipping on everything, we will ship to Canada and Worldwide. Domestic shipping is UPS Ground and varies from $10-15 for most items (excluding larger and heavier parts and body panels) to anywhere in the lower 48 states. Contact us for a quote if you live elsewhere.
    Note, the list below is a general overview of pricing for common items that we currently have in stock.
    Engine
    Complete 1.8T Engine w/Wiring Harness (Code "AEB") - $1200 (137,901 Miles)
    Transmission - $500
    Turbo K03 - (Minimal Shaft Play - GOOD!) - $150
    Timing Belt Covers - $25/ea
    Belly Pan - $50
    Throttle Body - $125
    Intake Manifold - $50
    Exhaust Manifolds - $50
    MAF w/Sensor - $85
    Power Output Stage (POS) - $60
    Coil Packs - $15/ea
    Fuel Rail - $40
    Fuel Injectors - $15/ea
    Engine Mounts - $40/Ea
    A/C Compressors - $50
    A/C Condenser - $50
    Radiator - $50
    Radiator Core Support w/o Fans - $150
    Radiator Cooling Fan (Electric) - $60
    Viscous Fan Clutch (w/o Fan) - $40
    Viscous Fan Wheel - $20
    Starter - $50
    Alternator - $50
    Oil Cooler - $30
    Power Steering Cooler - $30
    Power Steering Pump - $65
    Differential - $50
    O2 Sensors - $40/Ea
    Coolant Reservoir w/sender - $30
    Wiper Motor - $30
    Wiper Linkage - $50
    Washer Spray Nozzles (Headlight) - $40/Ea
    Washer Fluid Reservoir - $40
    Washer Fluid Pump (Main) - $40
    Washer Fluid Pump (Head Light) - $40
    Shift Linkage (5sp) - $40
    Air Filter Box - $40
    Air Filter Box Ducts - $20/Ea
    Fuel Pump - $80
    Fuel Sending Unit - $30
    Drive Shaft w/Carrier Bearing - $100
    Clutch w/Flywheel - $150
    Brakes/Suspension
    ABS Speed Sensors $40/Ea
    Brake Calipers w/Carriers - $50/EA
    Brake Booster - $40
    Brake Master Cylinder - $40
    Brake Fluid Reservoir - $25
    Front Rotors - $15/Ea
    Rear Rotors - $15/Ea
    Tie Rod Assy- $40/Ea
    Control Arms $40/Ea
    Differential - $50
    Axles Rear - $50/Ea
    Axles Front - $50/Ea
    Rear Knuckles/Knee Assy w/Hubs - $50/Ea
    Exterior/Body/Lighting
    Corner Markers - $30/Ea
    Driver's side Mirror Housing (No Glass) - $50
    Passenger's side Mirror Housing (No Glass) - $50
    Trunk - $150
    Grill (Badged) - $40
    Bumper Grille Lower (L/R) - $30/Ea
    Bumper Grille (Center) - $40
    Window Frame Assy With Windows (no Motor) - $75/Ea
    Side Windows (Glass Only) - $50/Ea
    Window Frame Assy W/O Windows (no Motor) - $25/Ea
    Front Fenders - $100/Ea
    Door DS Front - $100
    Door DS Rear - $100
    Door PS Front - $100
    Door PS Rear - $100
    Exterior Door Handles - $40/Ea
    Fender Liners - $30/Ea
    Moon Roof Assy Complete (Glass) - $150
    Rear Bumper Assy - $150
    Rear Bumper Shocks - $40/Ea
    Front Bumper Assy - $200
    Front Bumper Shocks - $25/Ea
    Door Weather Stripping all four doors - $20/Ea
    Rear Tail Lights - $60/Ea
    Tail Light Bulb Holders - $30/Ea
    Interior/Electrical/Stereo
    4 Spoke Steering Wheel - $60
    Instrument Cluster - $60
    Beltline Trim- $150
    Climate Control - $60
    Central Locking Pump - $100
    Cruise Control Module - $60
    Airbag Module - $80
    ABS Computer - $100
    Shifter Knob Black Leather - "Sport" - $50
    Shifter Boot Black Leather - $25
    Radio - Non-Bose Delta with Code - $75
    Non-Bose Speakers - $40/ea
    Pillar Trims A,B,C Ecru- $30/ea
    Headliner with Sunroof cut-out - $100
    Dash - $100
    Passenger Air Bag - $100
    Sunroof Switch Panel w/Lights (Good Condition) - $60
    Front Driver's Seat (Leatherette) small tear- $100
    Front Passenger Seat (Leatherette)- $100
    Rear Seat - $100
    E-Brake Handle - $30
    Door Pulls Black (no switches) Good Condition! - $40/Ea
    Sun Visors - $20/Ea
    Column Switches/Stalks $30/ea
    Window Switches - $10/Ea
    Seat Heater Switches - $15/Ea
    Interior Door Handles Black/Silver Good Condition - $30/Ea
    Sunroof Motor - $75
    Window Motors - $40/Ea
    Window Regulators - $40/Ea
    Kick Panels - $20/Ea
    Heater Box Complete w/Heater Core, A/C Evaporator and Fan Motor - $100
    Blower Motor Fan Assy - $60
    Rear Window Deck w/3rd Brake Light - $50
    Tilt Steering Assy. w/ignition and Key - $60
    Center Heater Vents (3 total, sold separately) - $15/Ea
    Side Vents - $15/Ea
    Rear Vents - $15/Ea
    Overhead Grab Handles - $10
    Front Seat Belts - $50/Ea
    Rear Seat Belts - $25/Ea
    Interior Floor/Door Trim (from Front to Back) - $50
    Exterior Black Door Sills - $50/Ea
    Center Rear View Mirror (Windshield) - $40
    Again, for any questions or to order, shoot us a PM through AZ or an email at [email protected].
    We have our ENTIRE parts inventory posted on our eBay Store--over 900 individual items from 96-01 A4s, 92-97 100s/A6s, V8 Quattros, etc.--all posted with pictures. Browse our inventory at your convenience! THANKS FOR LOOKING!!!
    We look forward to being of service to you and your Audi!!!!!!
    A&P Auto Specialties, LLC • 1960 County Road 90, Suite 100 • Independence MN 55359
    97 A4 2.0TQM
    Rochester, NY
    Re: Parting out: 1997 Santorion Blue A4 1.8T Quattro 5 speed
    That's Europa Blue, there was no Santorin in 96 or 97
    Mar 15 2008
    A few Audis
    Independence, MN
    Quote Originally Posted by pac1085 View Post
    oops! Thanks for the correction!
    Veteran Member Three Rings Castor Troy's Avatar
    Dec 17 2008
    Billings, MT
    Re: Parting out: 1997 Europa Blue A4 1.8T Quattro 5 speed
    that car looks too nice to part out :(
    Account Terminated Four Rings
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    I see Rob's car.
    Mar 15 2008
    A few Audis
    Independence, MN
    Quote Originally Posted by Castor Troy View Post
    Unfortunately it is but we need a fresh inventory of parts for you guys!!
    Quote Originally Posted by ILoveT View Post
    I see Rob's car.
    yup my car is beating winter the easy way this year
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    What is wrong with the car that you have to part it out?
    Mar 15 2008
    A few Audis
    Independence, MN
    We need parts to sell. That is pretty much all. The brake system of the car is completely shot and the seller offered it to us at a great price. Instead of just fixing it to sell, we decided to part it out because our inventory is getting low.
    Established Member Two Rings PreLunatic's Avatar
    May 01 2008
    2001 A4 1.8tq
    Chicago|Lithuania
    Would the '97 front speakers be the same as the '01? if so, how much for just the front driver side speaker? Thanks.
    2001 Black A4 1.8t-APR 93 Chip.Forge 007 DV.Custom Cat-Back.B6 A4 Rims.Vmaxx coils.Debadged.
    -Arnold-
    Mar 15 2008
    A few Audis
    Independence, MN
    Quote Originally Posted by PreLunatic View Post
    Are you non-bose? If so, then yes they will work. P/N 8D0 035 411A and B
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Well what if someone wanted to buy it?
    May 01 2008
    2001 A4 1.8tq
    Chicago|Lithuania
    Quote Originally Posted by AP-Specialties View Post
    Yeh non-bose.
    -Arnold-
    Mar 15 2008
    A few Audis
    Independence, MN
    Its a parts car We need to keep our shelves full to keep the business coming
    Mar 15 2008
    A few Audis
    Independence, MN
    Bump
    Veteran Member Three Rings black00A4's Avatar
    Oct 19 2006
    Ontario, Canada
    A4 Rob is a good seller.
    2000 Audi A4 2.8L Quattro Sport - Volcano Black
    Mods: 18" A8 Rep's, Ebay SS & Strut tower bar, PureMS Snub mount, K&N, MAF de-screened, H&R sports, STERN power ring & diff mounts, Cupra Lip, DEPO ecodes, Unitronic flashed ECU, Magnaflow
    Mar 15 2008
    A few Audis
    Independence, MN
    Bump! Check out feedback from other buyers here:
    You can even read this negative thread about us:
    Customer satisfaction is literally our #1 priority.
    Oct 19 2006
    Ontario, Canada
    I would like to excuse or retract my previous post, Rob came through and gave me a full refund. I was just alittle angry that this happen and thats all. The transaction went without a hitch and his shipping was very fast. Just unfortunet this had to of happened. I will buy from him in the future.
    Mar 15 2008
    A few Audis
    Independence, MN
    Quote Originally Posted by black00A4 View Post
    No worries. We are here for you guys We go through every car with a checklist and mark which items are broken, or are in bad shape. Those items go no where except the trash
    Established Member Two Rings twofaze's Avatar
    Jul 27 2008
    Fort Worth, Tx
    that interior is nice....
    Mar 15 2008
    A few Audis
    Independence, MN
    Bump
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Can I have the front Audi rings?
    Mar 15 2008
    A few Audis
    Independence, MN
    They are sold with the grill.
    Veteran Member Four Rings A4orce84's Avatar
    Feb 12 2004
    Austin, Texas
    Can I get the window regulator wheel:
    USP CLUB MEMBER #101
    2004 A4 1.8T USP - APR Stage 2+, Mototec Sport Exhaust w/AWE downpipe, Valeo Clutch Kit, 2.0T FSI Coils, EVOMS Diverter Valve, Boosted Intake, B5 S4 Front Brakes, RNS-E + Bluetooth Module, VMR 708s (RS4 Reps), Boost Brothers FMIC, '02 OEM Sport Suspension + B5 Front Perches, PODi, JHM Solid Short Shifter, JHM Solid Linkage Upgrade, and a lot more stuff!
    Mar 15 2008
    A few Audis
    Independence, MN
    YGPM!
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    So you're telling me you have NO spare Rings laying around your shop?
    Mar 15 2008
    A few Audis
    Independence, MN
    Not that I am aware of. I can sell you a complete one for $40 plus $10 shipping.
    Mar 15 2008
    A few Audis
    Independence, MN
    Bump
    Mar 15 2008
    A few Audis
    Independence, MN
    Mid Week Bump! keep the requests coming
    Mar 15 2008
    A few Audis
    Independence, MN
    Thanks for the orders everyone! Keep them coming!
    Mar 15 2008
    A few Audis
    Independence, MN
    Bump, plenty of parts still available on this car!
    Mar 15 2008
    A few Audis
    Independence, MN
    Bump
    Sep 28 2006
    Lexington
    Spare tire hold down. The clips that holds down passenger side floor mats?
    Do you have pics of these? Also the cover that covers open hole in the rear ashtray?
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    K04 | GIAC PC-16 | FMIC | 3" Neuspeed Exhaust | ATP Test Pipe | Raceland Coilovers | N75 Race | Forge 007 | K&N | VDO Boost Gauge | A8 BBK | Rear Fog Light Mod
    07 A4 3.2LQ - K&N
    Mar 15 2008
    A few Audis
    Independence, MN
    YGPM AudiTurbo
    Mar 15 2008
    A few Audis
    Independence, MN
    Bump
