A friends car is having some issues after installing a forge wastegate, FMIC and new vacum lines + MBC only spikes at 8psi in first gear until 3k rpms and then drops to 5psi, in all other gears the car only holds 5psi in some high gears it also drops a bit. If you turn just a bit the MBC gets a limp mode and reads overboost.
