Results 1 to 10 of 10
    Veteran Member Four Rings Quattrocket's Avatar
    Sep 02 2004
    2001 Audi S4
    Guelph, Ontario
    Help find a home for this stray connection. Part 2.
    Got these 2 horn connections but cant locate where they plug into. anybody know where on the body they find their mate? heres some pics of them...
    MITCH
    "Audis are like strippers. They only work when you throw money at them."
    FORGE MOTORSPORT DVs*K04 TURBOS*034 TURBO INLETS*STAGE 3 SOUTHBEND CLUTCH(MANGLED PP MOD)*
    Account Terminated Four Rings
    2001 S4 GT28, 2001 S4 168K
    Long Island, NY
    Re: Help find a home for this stray connection. Part 2.
    those are your foglight connectors
    Sep 02 2004
    2001 Audi S4
    Guelph, Ontario
    Hmm, they were tied up pretty tight and Canadian S4s don't come with fogs. maybe Audi wired the car for them but never installed them?
    MITCH
    Veteran Member Four Rings Rhynolite's Avatar
    Sep 12 2007
    A
    How is that driverside one a foglight connector? Doesn't seem long enough.
    I have the same stray wires BTW, and was wondering the same thing.
    Long Island, NY
    what color wires are in the wire loom?
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    those are fog light connectors. audi did have them wired for fogs even tho Canadian s4's didn't come with them
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Sep 02 2004
    2001 Audi S4
    Guelph, Ontario
    Quote Originally Posted by 2001S4NY View Post
    Green/yellow or white (hard to tell) and brown. Same on both sides.
    MITCH
    Sep 02 2004
    2001 Audi S4
    Guelph, Ontario
    Quote Originally Posted by AMC View Post
    Awesome! thanks mang.
    MITCH
    Established Member Two Rings RenegadeEngr's Avatar
    Jun 15 2008
    San Francisco
    Fogs! I know this too well because mine broke and I fight those wires every time. I guess I could tie them up, but usually I'm too frustrated at that point in the reassembly...
    2001:Silver:S4:DarIntake:ABT Chip
    Mechanical/Fluids Engineer
    Senior Member Three Rings archimense's Avatar
    Jan 16 2006
    Vancouver, Canada
    Thread Jack
    Has anyone looked into retrofitting fog lights?
    2001.5 Audi S4 stg 3
    K04s, 85mm MAF, 60lb injectors, custom software
    ASP DTS/Tru-Dual/Downpipes
    Stasis Tracksports/4:1 Centre Diff
    Neuspeed 19mm rear sway - CPP rear end links/tie rod ends/front upper control arms
    VAST ceramic clutch, RS4 pressure plate, JHM shifter
    RS4 engine/trans mounts, Stern rear diff/snub mounts 55 watt HIDs, Odyssey PC680 battery, Innovate Wideband
