Originally Posted by
adr3naline fix
So he's either mistaken or wants to make a bigger sale huh?
Southbend said that their stage 4 is 228 so it wouldnt work with my 240mm, so they say I need the whole 240mm kit ... yeah, I'm lost.
He's not trying to screw you.
305AHWP / 0.78 = ~391bhp. On a 4cyl (or at least ours) you're not going to make as much torque as you will HP. I don't know why you would need a stage 4 clutch.
The 70205SS is made for the 228mm stock flywheel diameter. The 240mm flywheel is the diameter for the 2.8/2.7T clutches.
The 70205SS will hold the power you will make, but it would require you to use a different flywheel, since the RA4 kit is a 240mm.
Southbend 240mm (S4 kit) K70286 (straight from their website)
Stage 1 holds 400lb/ft and is $550 as advertised (Rally series)
Stage 2 holds 475lb/ft and is $650 ... (TZ series)
Stage 3 holds 525lb/ft and is $750 (OFE series)
Stage 4 holds 600lb/ft and is $825 (FE series)
SPEC: (again, straight from the site, S4 kits to fit the 240mm)
Stage 1 420lb/ft $620
Stage 2 490lb/ft $800
Stage 2+ 543lb/ft $840
