Results 1 to 11 of 11
    Established Member Two Rings mathieums's Avatar
    May 05 2007
    Audi A4 1.8t Quattro 1997
    Montreal, Quebec, Canada
    If my battery die, can I still unlock my doors?
    I did a test yesterday, I disconnected my battery terminals and then I tried to unlock my locked doors and nothing happened...
    Does that mean if my battery die that I can't unlock my doors anymore?
    And don't tell me to pass through the trunk cause that won't work since the back seat don't have any handles to fold them from that way.
    Since the system is fully electrical, is there anyway to manually unlock my doors?
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    Re: If my battery die, can I still unlock my doors?
    The remote won't work, but you should have no trouble using the key.
    The door you put the key into will unlock, but the others won't.
    Oct 27 2006
    Pearl 98.5 Audi A4 1.8T
    Fargo, ND
    Quote Originally Posted by mathieums View Post
    That's a great quote. Do you not have key holes or something?
    1998.5 1.8TQT (SOLD)
    Joined the Dark Side
    2008 Honda Pilot SE
    Sep 13 2008
    Western Chicago Burbs
    put the key in the hole and turn it and if that doesnt work climb through the trunk
    May 05 2007
    Quote Originally Posted by tdn View Post
    I always use my key since I dont have any wireless entry system.
    I searched a bit after I posted.
    I think the previous owner tooked out the manual lock system because suposedly it was easier to break into the car.
    Heres a link:
    http://www.audiworld.com/tech/int47.shtml
    Aug 29 2007
    Paktia, Afghanistan
    That would make sense.
    I've thought about removing mine also, but like you found out, if your battery dies or the pump fails, you're fucked.
    When it gets warm out, I'm going to try to rig something up so I can discretely open my hood from the outside and hope my pump doesn't fail suddenly. It bothers me that our cars are so easy to break into. I plan to get a killswitch in there also.
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    or you could run a seperate charge/battery strictly for the locking system.
    Oct 27 2006
    Fargo, ND
    Never saw that one before. Interesting, maybe the guys out in/near Jersey need to see that :)
    Not sure how hard this would be, but maybe relocate your battery to the trunk.
    2008 Honda Pilot SE
    Nov 30 2008
    06 Wrx
    Olympia, WA
    i Agree with a different way to lock the doors besides electrical. mine weren't working for a while so i had to leave one door unlocked. Got my ipod stolen :( now i have to use these things called CD's.
    Oct 29 2005
    10speed
    San Francisco, CA
    on the B6 there are not even pins
    - Clint
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Heres a link:
    Odd, I pulled out mine when I did my CF doors and yet I can still unlock my driver door with my key.
    The wires on the key tumbler are to turn off/on the alarm and unlock/lock all the doors. But you can still unlock the driver door using the key even if remove those wires from the tumbler. It isn't like everything in the driver door is electronic, there are still rods connected to those parts.
    Funny thing is that the people stealing the cars dont do what the person wrote in that article. They dont actualy hit the rod to unlock the car. They punch the door with a screw driver to ground the unlock wire which also happens to turn off the alarm. This is why they are able to get into the car without the alarm ever making a sound. If they hit just the rod to unlock it(like using a slim jim) the alarm would sound.
