Results 1 to 4 of 4
Thread: race gas files
    Jan 07 2009
    columbus, ohio
    race gas files
    has there been any dynos comparing pump gas to race gas. ive searched but havent found what i was looking for, just that race gas does make a difference.....just curious on HOW big of a difference we are talking here.
    Jan 07 2009
    columbus, ohio
    Re: race gas files
    yes i mean running race gas on a race file..
    Veteran Member Four Rings Justincredible's Avatar
    Jul 24 2008
    chicago
    Re: race gas files
    I'm sure there is some power to be had from race gas on the Audi. But all in all 90% of the OEM motors don't pick up much with Race gas.
    As it is the car on pump gas will give you 26-28 deg of timing. Some chip cars will give you 32 deg of timing on pump. Other then the tuners that don't pump the timing up for the standard chip so they can sell you a "RACE GAS" file there doesn't seem to be much room left for power timing wise.
    So im with the not a big room for power with Race gas. Unless you live in cally where the pump is 91 or less.
    If you don't have haters, then you're not kicking enough ass.
    JHM powered 12.2 On the JHM Tune With Launch Assist for the Automatic JHM Nitrous kit/JHM headers all this in a Automatic.
    And lastly for the grammar police that are bound to step in
    I came here from Germany in the 6th grade. I could not read or write a lick of English. I am working to get better. Thanks and sorry. I always try to edit my posts for the best grammar and easiest reading.
    Stage 2 Banner Advertiser Four Rings jaybquick@JHM's Avatar
    Aug 24 2005
    Lathrop, CA
    Re: race gas files
    We have been working on tunes for these cars and it depends on the gas that you have in your area.
    If your car is already making timing in the high 20s with your existing gas (93 or 94 octane in some states can do it) then you probably wouldn't see much gains. Out here in CA on our 91 octane we do see improvements when mixing some 100 octane unleaded with the 91 octane gas. We can get the timing below 4500 rpm to increase by 14 to 15 degrees for more low end torque. The gains were decent as well.
    It all depends on what timing your car is currently able to make (limited by knock sensors and the ECU tune). Log block 003 and 020 and do a full throttle pull in third gear from 1500 to 7000 rpm and email me the log. I can let you know how your gas is doing with the tune you have.
    JHMotorsports AZ tuner spotlight VIDEO
    Check out our 11 and 10 second passes on YouTube
    B8 S5 4.2l - JHM Stage 1 SC Kit (ET: 11.8 @ 119mph) -- B6 S4 - JHM Stage 2 SC Kit (ET: 11.1 @ 128mph) – JHM Nitrous (ET: 12.29 @ 117mph) - JHM Bolt Ons -ALL MOTOR (ET: 12.70 @ 111mph) -- B5 S4 - JHM RS6-R (ET: 10.8 @ 130mph)
