Results 1 to 4 of 4
    Established Member Two Rings FknChizA4's Avatar
    May 19 2008
    Audi A4 B5 1.8t
    Pasadena,CA
    Exclamation I Need Some Help!!!!!!!
    ok so i had posted a thread about my check eng light. well 2 day after work turned my car on.. heard my turbo spoil right as i turned it on which was wierd to me.. my car sound different well i was driving home and could hear my car whistle loud and kinda of a spraying sound when i would hit the gas.. at first i thought i blew my dv.. then i thought my turbo went bad but there was no smoke.. so i get home pop the hood look and i see sum red glowing... my xat is comming off so that why i could hear my turbo so loud.. so my question is what am i looking at money wise??
    Veteran Member Four Rings turbo kraut's Avatar
    Oct 30 2006
    09 pontiac vibe
    StL, Missouri
    Re: I Need Some Help!!!!!!!
    maybe i am too much of a noob, but wth is a xat?
    pictures would help...... might be something you can fix
    2001 Honda CBR929RR - modded - mine
    1992 Ford Bronco - The Beast - mine
    2009 Pontiac Vibe - stock - wifes
    1981 Suzuki GS1100 - sold
    2011 Ninja 650r - sold
    2001 Audi A4 - totaled 3/31/13
    2006 Honda CBR600RR - traded
    1982 Honda GL500 - sold
    2011 Ninja 250r - sold
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    if the turbocharger or cat are glowing, you probably have an exhaust restriction. if your exhaust manifold and turbo are glowing, you may be dumping fuel
    what do you mean your cat is coming off? are the cat guts (catalyst biscuit) chunking or flaking? or is the entire cat broken at the flange or coming unbolted or something? if the cat housing is ok, and there is not a lot of rust, i would say make a test pipe out of it for free (just labor and it is a PITA). if the cat housing is damaged or you need to pass emissions, i would say buy a high flow catalyst which is usually less than an oem replacement.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    May 19 2008
    Audi A4 B5 1.8t
    Pasadena,CA
    Quote Originally Posted by turbo kraut View Post
    haha sorry i was just fkn rushing to type.. i had a buddy come over and he helped me look more in to it to find the exact prob with it.. my cat welding came off the gasket.. so its completely separated now.. which made my turbo spoil loud and no sound from exhaust.. do you guys think there going to have to take out the gasket and start from the turbo??and pipe it all the way back. i was thinking of just geting my test pipe and just geting a custom exhaust..
