Results 1 to 13 of 13
Thread: HELP!!!
    Senior Member Two Rings Trotter715's Avatar
    Apr 05 2008
    New Jersey
    Exclamation HELP!!!
    Does anyone have the pin/bolt that holds the calipers in place??? I busted one of the two. It is the hex bolt, there are two. I need it for stock 2000 a4 1.8 brakes. PLEASE LET ME KNOW IF YOU HAVE ONE!!! I will gladly pay you for it. Audi only sells entire calipers, not the individual bolts.
    I'm a dog chasing cars, I wouldnt know what to do with one if I caught it.
    Veteran Member Four Rings Beemer832's Avatar
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    Re: HELP!!!
    my advice would be take the good bolt that you have, head to a hardware store and get one that fits. Make sure its METRIC and its an ALLEN head. Trying to find a used one off of someone is going to be just about impossible.
    Audi should have these, they aren't part of the caliper, they are part of the caliper mounting brackets. If the first audi guy can't help you, ask for someone else... damn monkeys working at these places these days :)
    good luck
    -josh
    -josh
    98 AEB 1.8t Laser Red
    EFR 6758 with VEMS standalone in the works.
    Veteran Member Four Rings hoganalley's Avatar
    Feb 23 2007
    Burlington
    Re: HELP!!!
    Audi will sell just the bolts. I bought them from a dealer last spring. If they say they don't have them, they're lying to you.
    14 A4 allroad - stock
    05 allroad 2.7T Stock
    Apr 05 2008
    New Jersey
    Re: HELP!!!
    i guess ill try another audi tomorrow. the one i talked to said they would only sell the entire thing and it would cost like 200 bills.
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    Re: HELP!!!
    yea they are full of shit and they know it :)
    -josh
    -josh
    Registered Member Two Rings
    Apr 19 2008
    215 PA
    Re: HELP!!!
    the rear carrier bolt that bolts into the knuckle! go to napa it will be like 3 bucks for a regular old bolt.. i had to do the same thing, you will never find a used one!!
    Aug 06 2008
    wayne pa
    Re: HELP!!!
    it would be nice if the dealerships didn't try to rape us !!!
    Apr 05 2008
    New Jersey
    Re: HELP!!!
    Napa had it, good looks. Unfortunately there is still part of the bolt stuck in the caliper so i have no idea how to get that out
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    Re: HELP!!!
    how much of it is exposed? you can use a bolt out, or a reverse drill bit. if its enough even some vice-grips
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Veteran Member Four Rings arorem's Avatar
    Mar 24 2008
    '99 A4 1.8TQ, '74 Triumph Spitfire
    Illinois
    Re: HELP!!!
    maybe a hardware store?
    Apr 05 2008
    New Jersey
    Re: HELP!!!
    there is very little sticking out. maybe a little bit more than the width of a toothpick
    Apr 19 2008
    215 PA
    Re: HELP!!!
    drill out the bolt using a small bit and work your way up but dont drill off the threads and then use a tap and die kit..
    Apr 19 2008
    215 PA
    Re: HELP!!!
    or whiz wheel enough for a screw driver and turn it out using pb blaster and a blow torch..
