Results 1 to 26 of 26
Thread: F*ck wipers
    Veteran Member Four Rings got boost.'s Avatar
    Jun 03 2007
    california
    F*ck wipers
    how do you remove the wipers after you unbolt it. i need to get it off to remove the ecu. i tried to pull it but it won't budge.
    l BBS l FORGE l STERN l VMR l ER l SPEEDTUNE l
    Jun 08 2008
    Calgary AB Canada
    Re: F*ck wipers
    wiggle it around. it'll go
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Re: F*ck wipers
    Dude - mine were a MAJOR pain. I can only get the driver's side off. At least that one lets me bend the cowling up enough to remove the ECU cover.
    I used PB blaster and a rocking/pulling motion to break the hold. They are held in by a weird conical shaped part - imagine the sides of a Reese's cup with all those ridges. You're trying to wiggle the wiper/reese's cup out of the post/reese's wrapper.
    I used a LOT of force and still couldn't get the passenger's side. Don't be afraid to get tough, but be careful that you don't break the windshield as you're tugging.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    CO
    Re: F*ck wipers
    If you took off the wiper bolt you should be all set. It should just pull straight out. I would mark on the windshield the current wiper position with some masking tape so you put it back on in the same location when finished.
    Quartz Gray '11 S4 Prestige || Sprint Blue '06 S4 Saloon - Sold || Denim Blue '02 A4 1.8T - Total Loss || Laser Red '98.5 A4 1.8T - Sold
    Oct 15 2006
    From a few to one...
    Arlington, VA
    Re: F*ck wipers
    i would try some pb blaster. worked for me. just let it soak in a bit, for like 30 min then come back and try to get them off.
    edit: whatever you do, don't turn the blade. just try to rock it off.
    '97 A4 1.8TQ, '02 A4 1.8TQ Avant, '03 A4 1.8TQMS, '04 A4 3.0Q Cabrio - Sold
    '18 S4 Prestige - Kohlefaser Luft-Technik Intake
    Veteran Member Three Rings davidlizard's Avatar
    May 01 2008
    2004 A4 ultrasport 6speed
    Winter
    Re: F*ck wipers
    I had the same problem last week to install my boost gauge... I did'nt succed to remove that F****** wiper but I did remove the ECU box cover without removing the wiper... you just need a lamp to find the idden bolt and your done. It's a little bit harder to replace the cover than removing it but it's possible... (to replace the cover I've used dish soap to make it slip)
    good luck!
    Unitronic stage 2+ / Borg Warner K04 / Milltek / ATP 3" testpipe / Racetec FMIC / Forge TIP / Carbonio / Forge DV / 386cc / 034 25mm rear sway /Joey moded / Podi / JHM 350mm BBK & SS lines / STaSIS street sport/ Michelin Pilot Super Sport / ECS Tuning lightweight flywheel + RA4 clutch kit /
    034 engine & trans mounts / 034 snub mount / 034 front & rear link / Apikol rear diff mount / JHM solid short shifter
    Senior Member Three Rings 03 silverbullet's Avatar
    Dec 05 2008
    1.8 Q 05 GSXR 03 CBR RR
    Re: F*ck wipers
    i had to use liquid wrench on mine and let it soak in
    Jun 03 2007
    california
    Re: F*ck wipers
    im going to try and find the damn bolt without removing the wiper.
    Dec 05 2008
    Re: F*ck wipers
    Quote Originally Posted by got boost. View Post
    there is only one you have to get to and its almost right under where the wiper arm is attached to the motor
    Jun 03 2007
    california
    Re: F*ck wipers
    Quote Originally Posted by 03 silverbullet View Post
    there is no way to reach the one under the wiper!!! you have to be crazy smart to find a way to do that.
    anywayz success!!!
    i got it out after a lot of wiggling. However, there is no security sleeve like on A4 mods so does that mean the ecu was tampered with before?
    Can't wait to get the ecu back and go faster!
    May 21 2007
    Florida
    Re: F*ck wipers
    seriously not that hard. grab a heat gun and heat it up a bit, pull straight up. wallah. done. you can try a torch but you may catch stray leaves and sticks on fire. be warned. i wouldnt worry about taping the windshield to mark the spot or anything like that. you know about where it goes, plus there will be a line of dirt anyway.
    2018 Navarro Blue Q5
    Veteran Member Three Rings Pete4 1.8t's Avatar
    Jan 13 2007
    '12 328i Sport, Others: '12 A8L W12, '12 S5 Cab, '11 P. Cayenne, '13 P. 911 C2S
    Greensboro
    Re: F*ck wipers
    My car was a bitch to remove the wipers, it was 4-5 hours of pulling (and cursing) until they finally let go. Audi actually has a special tool for getting them off.
    2003 Audi A4 1.8t 5-Speed
    Light Silver with Ebony Leather with Premium Package
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Re: F*ck wipers
    Just pick up one of these arm removal tools at almost any automotive supply store. Makes the job simple.
    Jun 03 2007
    california
    Re: F*ck wipers
    a little late but looks like that wouldve been a HUGE help.
    Veteran Member Three Rings braker15's Avatar
    Nov 15 2008
    2000 S4 Nogaro Blue
    S.Florida
    Re: F*ck wipers
    I have changed my whole frickin wiper transmission( it broke in half), It ws a pain to take the wipers off took me 2 days, than i finally went to autozone and got me a wiper removal tool. That was a bit tricky too, because the rod the pushes on to the wiper stud is round, there was no grip. So I had to use wise grip and a rag, to hold it in place. by the way that wiper tranny cost me $230 thats a hell of alot for a piece of metal...
    good luck
    Veteran Member Three Rings ThatGuyAlex's Avatar
    Jan 24 2008
    NorCal BayArea
    Re: F*ck wipers
    pull up the wiper first and then pull it off.
    Fastest slow car down mountain roads you ever saw!
    Veteran Member Four Rings Jeff's Avatar
    Feb 18 2004
    Los Angeles, CA
    Re: F*ck wipers
    You can also use this tool, sold at Harbor Freight for <$15, which can be used for other applications in the future and not just the wipers.
    If it does not bulge after some hard wiggles, you will need a tool (especially on the later models which become especially hard). In my case, I learned the hard way and a simple wiper arm removal cost me a new windshield.
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    Re: F*ck wipers
    Quote Originally Posted by Jeff View Post
    Have you actually tried using a pulley puller on the wiper? I was having a lot of trouble on a Passat and tried to use one but there was insufficient room between the glass and the bottom of the arm (the wide end of the taper) to fit the teeth. It was also a large metal tool right next to the glass, which was worrysome.
    Im going to buy a proper wiper tool like old guy recommended. Honest to god I hate swapping wiper arms, it can be such a freaking hassle if they are stuck
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Dec 05 2008
    Re: F*ck wipers
    anywayz success!!!
    What do you mean no security sleeve ? The silver piece that the is held on with the two black clap type things ?
    Why were you taking the ECU out anyways ?
    Apr 20 2007
    Lander, Wyoming
    Re: F*ck wipers
    The ECU is held in a metal sleeve that is secured with tamper proof bolts from the factory. Check out the APR ECU install instructions, there is a pic of it.
    Jon
    go > show
    Ich liebe mein Audi
    Senior Member Two Rings skizsam's Avatar
    Apr 28 2007
    Fairfield, CT
    Re: F*ck wipers
    I hear ya...this happened during the last snow/ice storm...simply annoying, but remove them once, and the 2nd time is much easier
    http://www.audizine.com/forum/showthread.php?t=253278
    2002 1.8T A4QM
    APR stage 1 | SouthBend Stage 1 | Reiger | BBS | Remus | AWE Boost gauge
    Dec 05 2008
    Re: F*ck wipers
    Quote Originally Posted by lookaught View Post
    i have taken out my ECU before. The ECU is whats held in with the little clap things. Had them mixed up
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: F*ck wipers
    I wish the bottom of our windshield had heating elements in it to keep the wipers warm in the winter like Subarus. That is the ONE thing I wish my Avant had.
    aka: ECU Chastity Belt
    -Doug
    Buncha motorcycles
    Memphis, TN
    Re: F*ck wipers
    thats a nice handy tool old guy put up.....
    those wipers were EFFING Bitches to get off! i thought i was going tobreak something for sure but i finally got them off
    APR Stage 2/AWE Intake
    Apr 20 2007
    Lander, Wyoming
    Re: F*ck wipers
    I swapped my wipers to Aero arms last night. This tool that OG posted was AWESOME. Picked it up for ~$12 at Advance Auto Parts.
    One hiccup was that it was not quite deep enough to center the screw over the wiper post, so once you loosen the nut you need to keep it on the post but threaded up about 1-2mm to create a "bowl" for the screw to seat into. Also the driver's side arm was a bit more difficult to get this tool onto, but it does go on with some elbow grease.
    I cannot express in words how much frustration this saved me last night. Once it was on it took about three seconds per arm to get it broken loose off the taper, then just remove the nut all of the way and the arm pops right off. I had both wipers swapped and ready for snow in under 20 minutes.
    Thanks OG!!!
    Jon
    go > show
    Ich liebe mein Audi
    Veteran Member Four Rings a4wd's Avatar
    Jul 27 2004
    B6 1.8TQM 5speeeeeeeed
    Bay Area 925
    Re: F*ck wipers
    what flash are you getting kevin?
    another stereotypical Audi
