Results 1 to 14 of 14
    Veteran Member Four Rings FrankA6's Avatar
    Mar 30 2008
    2004 A6 2.7T, 2012 Volvo S60 R-Design
    Pittsburgh
    30ET on an 2004 A6 will it work?
    like it says, is anyone running 30ET offsets on their A6, if so let me know, and can i see some pics? thanks!
    2004 Audi A6 2.7T
    Apr 18 2007
    ny
    Re: 30ET on an 2004 A6 will it work?
    30et offset on what width wheel??
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Veteran Member Four Rings 2.slowT's Avatar
    Sep 24 2006
    2002 Audi A6 2.7T
    Minneapolis MN
    and the saga continues over here too
    Poor old Franks gonna loose some hair on this one.
    2002 A6 2.7T Sport
    2000 A4 Avant Daily
    C5UNION | pictures & timeline
    Mar 30 2008
    Pittsburgh
    8.5 inch wheels , 19x8.5 30et , will it work? i can always run spacers, plus if i get these wheels, instead of my LM Reps, they are real 3 piece, that way i can get some bigger lips :)
    2004 Audi A6 2.7T
    Apr 18 2007
    ny
    I talked to a guy at raderworks and he told me that a 30mm offset on a 19x8 would fit fine, so I'm pretty sure it would be fine on an 8.5 depending on how low your car is.
    SOLD
    Greg
    C5UNION
    Mar 30 2008
    Pittsburgh
    im a risk taker, theres always a way, either spacers or rolled fenders, plus i just ordered stern adj control arms :)
    2004 Audi A6 2.7T
    Nov 19 2005
    Pair of (. )( .)
    don't forget HE HAS 4.2 !!!!! ;)
    -Andrey
    Stanced and Tuned Brilliant Black RWD C5 A6 2.7T 6MT
    Nov 19 2005
    Pair of (. )( .)
    Frank you need to chek with the audi tech, what is your original offset?
    -Andrey
    Apr 18 2007
    ny
    Quote Originally Posted by kievskiy View Post
    who has a 4.2??
    SOLD
    Greg
    C5UNION
    Sep 24 2006
    2002 Audi A6 2.7T
    Minneapolis MN
    Franks sig say 2.7
    2002 A6 2.7T Sport
    2000 A4 Avant Daily
    Veteran Member Three Rings Kemer1's Avatar
    Aug 26 2008
    05 Audi A6 3.2 Quattro
    Sin City
    Well going to a et30 will actually bump your wheels out farther, so you won't need a spacer...but that actually depends on the design of the spokes. Here's a wheel offset calculator that will help you figure out what the wheel will do and how much. Then just measure on the car to see if it will clear.
    Nov 19 2005
    Pair of (. )( .)
    HAHAHA, sh1t, my bad, your sig says 4.2 door blades, i didn't read it carefully
    sorry
    Quote Originally Posted by A62TURBO View Post
    who has a 4.2??
    So Franky, if your offset is 43mm also, then 30 will be def. out of the front fender, rears might be ok....i guess test fit is the best, lol
    -Andrey
    Mar 30 2008
    Pittsburgh
    they are coming off a b7 a4 and they dont stick out, and i ran 18x9 with 35ET last summer, so i really dont think 5mm is going to mean much.....plus i want them out to fender if not a little poke. and they are flat spokes 3 piece wheels like LM's
    2004 Audi A6 2.7T
    Mar 30 2008
    Pittsburgh
    my winter wheels, are 18x8 with 35ET and look how much they are in, i looked on the wheel calculator and it says this.
    Inner Clearance: 1mm LESS
    Outer Position: EXTEND an extra 11mm
    so looks fine for me, now take a look at how much room i with the 18x8 35ET's on, they are in really far, so they will be in 1mm Less and stick out 11mm More. the back im thinking is going to need about a 10-15mm spacer to look good. front should clear everything, since i dont HP2 brakes im not worried, plus i just ordered Stern Adj Control arms, so the camber can be messed with some to make it perfect and no more premature tire wear!
    oh and BTW i put in the size of my old summer wheels, and it says EXTEND an extra 13mm , so im fine, these should be about 2mm less poke then my old setup, and they had a ton of clearance and never had rubbing problems :) so all in all, i think im fine.
    2004 Audi A6 2.7T
