Results 1 to 17 of 17
Thread: Piggies
    Jun 16 2008
    2000 Audi S4 Nogaro - SOLD
    Colorado
    Piggies
    Is $350 a good price for Piggies?
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Re: Piggies
    I say save your money for a different mod and just make piggies out of your own dp's if you can take the dp's off you can gut the precats yourself and put them back on.
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Jun 16 2008
    Colorado
    Re: Piggies
    How big of a pain is it?
    Veteran Member Three Rings nateS4's Avatar
    Apr 25 2008
    01.5 Nogaro S4 6spd, 02 GSXR, MkIII TDI
    Baltimore
    Re: Piggies
    I did my own, just takes time....gointoscott has a good DIY that saved me some time.
    2001.5 S4 Nogaro Stage III
    Test Pipes|AWE Twin1|Forge Hybrid BOV/BPV|JHM MBC|VAST Tuned|FrankenTurbos|034 Mounts|Hotchkis S-bars|RS4 Grille/Knob|50w HIDs|Vogland/Bilstien|JHM SS
    02 Suzuki GSXR Telefonica Movistar
    88 Bimmer E30 Vert
    98 Jetta TDI
    90 Corrado G60 Sold!
    92 Audi 100 Sold!
    http://photobucket.com/nateS4
    Jun 16 2008
    Colorado
    Re: Piggies
    Thanks
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Re: Piggies
    Veteran Member Three Rings VinNyS4's Avatar
    Nov 07 2007
    New York City
    Re: Piggies
    if you want i have a set of stock downpipes because i have ssac downpipes..if interested pm i could gut them for you for a much more decent price then 350.
    10 b8 s4 6MT sprint blue / black & silver
    Oct 31 2007
    F21-e85 S4 MKIV BPM R(T)32
    Grand Rapids, MI
    Re: Piggies
    Quote Originally Posted by TPC303 View Post
    Um, no!!
    Tony sold me his set of his personal car for like $180 SHIPPED, and it was a last minute type thing too!
    MKIV BPM R32 (DD)
    2000 B5 S4 3L GT2860 build in progress...if only I could get my parts quick enough
    Aug 06 2008
    Canadia
    Re: Piggies
    if you got a tip, i recommend you drop the tranny. I did piggies with the tranny in place and it was a total bitch.
    the B5 S4 is like the mafia... there is only one way out!
    Senior Member Two Rings curlyfrieS4's Avatar
    Nov 19 2008
    S4 Twiny Terbs
    San Diego
    Re: Piggies
    do you know if you could still pass smog/emissions test with piggies?
    Sold: 2000 S4 Stage II: 17' BBS RGRs. GIAC X. JHM FMIC. Piggie pipes. 710n's. RS4 clutch & flywheel. BORLA Cat Back. UUC Short Shifter. Stasis Coilovers. Need Brembo brake kit!!!!!!!
    Current: 2001 Audi S4. Stock :)
    Veteran Member Three Rings Ianxcom's Avatar
    Jul 30 2008
    Socal/Denver
    Re: Piggies
    Quote Originally Posted by curlyfrieS4 View Post
    I have no personal experience in this subject but from my research the answer is yes.
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Re: Piggies
    I put defoulers on when I made my piggies as I showed in the DIY.
    Here in Wisconsin they use odb-II testing for passing emissions. As long as there are no codes when you take the test you will pass.
    I passed a few weeks ago - took 5 minutes in and out and I was done.
    At least here in Wisconsin thatis how it works, I think a lot of states are that way too.
    Jun 16 2008
    Colorado
    Re: Piggies
    I have a 6 speed, so do I need to drop the tranny?
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Re: Piggies
    No you will not have to drop tranny for 6 speed. look at the DIY i linked to earlier and you will have no problem.
    also you will not have to drop tranny for a tip. just lower subframe a lttle to give yourself more room. Its all documented in DIY.
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    Re: Piggies
    I ened up putting ASP DP's on my tip, they fit and don't rub. Lowering teh subframe helps alot as gointoscott said, Good luck
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
    Sep 27 2007
    00 S4 6sp, 06 Mazda3 HB Auto
    Columbia, SC
    Re: Piggies
    Also lift the car up as high as you can.
    00 B5 S4 - K04, Stern Soft MM, Stern Snub, DTS, Neuspeed Rear Sway, Oinkies, GIAC stg 2 XR, Vogtland GT, SSAC copy. Soo... Stg 2.31456?
    06 Mazda3 - Wife's car and autox car
    96 Eclipse GSX - Gone
    03 Acura CL Type S - Gone
    96 Soarer GT - Gone
    93 RX7 R1 - Gone and missing her
    Active Member One Ring toxcmtrpls's Avatar
    Jan 30 2008
    Woodland Hills, CA
    Re: Piggies
    Quote Originally Posted by gointoscott View Post
    im really thinking about doing piggies on my tip. how do i go about dropping the subframe? do i need to support anything with a jack? or do i just loosen the bolts a few turns?
