Page 1 of 3 123 LastLast
Results 1 to 40 of 94
    Senior Member Three Rings 03 silverbullet's Avatar
    Dec 05 2008
    1.8 Q 05 GSXR 03 CBR RR
    Why not 1000 HP ?
    Just simply put
    Why is it that an EVO can be built to 1000 hp and some guys on here with fully built motors are getting only into the 500 ? ( Im not trash talking anyone here with a built motor or anything like that.All i have on my car is a GIAC chip)
    Was it the motor design, support for the A4 ?
    Until i started having problems with my A4 a few months ago and reading on here how to fix things. I really didn't know much about its ability for performance so thats why i ask the question.
    Buncha motorcycles
    Memphis, TN
    Re: Why not 1000 HP ?
    evo's have a bigger motor enabling them to run bigger turbos i know... and they are heavier built and i thought i read they can be built to run to 10,000rpm taking full advantage of gt40+ turbos
    APR Stage 2/AWE Intake
    Dec 05 2008
    I thought the EVo was only a 2 liter.
    To get to 1000 they do run bigger turbos but they also replace everything that some guys on here have. rods, pistons, valves, port heads ect.
    So is it that the blocks are heavier built ?
    Feb 17 2005
    Sarasota, FL
    Most of the high HP EVO's are either 2.2 or 2.4l strokers ... plus their head flows massive CFM's with work done to them, and they run ridiculous turbo's
    Oct 29 2005
    10speed
    San Francisco, CA
    to make a long story short, Audi people are scared to try anything that, God forbid, would spool later and sacrifice drivability
    - Clint
    Jan 01 2008
    Long Island NY
    I know that a 2.0T on a GTI with Rods, FMIC, Exhuast, Rods, GT3571R Turbo Kit put down 605WHP a Evo with similar mods need a GT4076R to get that power.
    Dec 10 2008
    The amount of money it takes to get a car to 1000 horsepower I'd just buy a new car.
    2004 Black Audi A4 1.8t Quattro 6-Speed
    Dec 05 2008
    Quote Originally Posted by A4ringedONE8T View Post
    oh ok and you cant stroke the A4 to 2.4 because it would remove to much of the cylinder wall ?
    Dec 05 2008
    Quote Originally Posted by qirex View Post
    For which car ?
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by 03 silverbullet View Post
    the bore size at 83mm is already pushing it. You would need an insane stroke to get 2.4 and the pistons would be popping out of the block
    - Clint
    Dec 05 2008
    Quote Originally Posted by Auditude2.0T View Post
    Wow 605 is alot for car the size of a GTI
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    If you want 1000hp, I can build it for you, just don't expect to walking away with much change from your $50k check...
    Bigger cams, solid lifters, cnc ported head, super low compression ratio, twinscroll 42R, and a built to shit drivetrain and fuel setup... Oh yea, and don't expect 200wtq until after 5500rpms... Not to mention you need to run around on Q16/C16 everywhere, rev to 10k+ to get that power, and you need your engine to be torn down and checked every 5k miles or so (if that)...
    So, do you really want to do this to your Audi? No? Didn't think so... That's why no one else has either, there's no point... 1.8T's have put down over 1000hp, just not in Audi's
    Oct 29 2005
    10speed
    San Francisco, CA
    Your talking about FWHP, Evos make AWHP, which is another 10% drivetrain loss.
    And keep in mind, the aftermarket support for these is HUGE.
    Evos have a HUGE variety of cams, intake manifolds, etc etc
    Also, most of their street FMICs are double the size of our "race FMICs"
    - Clint
    Dec 05 2008
    So with the design of Audi motor then its impossible to go over 2.0
    Dec 05 2008
    Yea i now the support for them is nuts
    Dec 06 2007
    ^^precisely the EVO guys start with heavy 2.0L engines we are pushing our 1.8s to 2.0 maybe even 2.1 but that's about all it'll handle why do u think 2.7 TT out of the S4 make so much power
    simply put:
    There is no replacement for displacement.
    -Kirk
    BetaAlphaTau Member #58
    Oct 29 2005
    10speed
    San Francisco, CA
    we can do 2.1, if you buy a TDI block you can do 2.2
    - Clint
    Dec 05 2008
    Quote Originally Posted by AudiA4Turbo22 View Post
    ^^precisely the EVO guys start with heavy 2.0L engines we are purchasing our 1.8s to 2.0 maybe even 2.1 but that's about all it'll handle why do u think 2.7 TT out of the S4 make so much power
    simply put:
    There is no substitute for displacement.
    i am not familiar with all the different audi models so i will go look that one up
    Oct 27 2007
    In the lab
    simply put:
    Huh?
    Dec 05 2008
    Has anyone done that ?
    Oct 29 2005
    10speed
    San Francisco, CA
    simply put:
    there are 1.8L cars that make 1000hp too... it can be done, quite honestly though, Audi people suck
    - Clint
    Dec 06 2007
    ^^ a 2.7TT V6 in the B5 S4 is capable of about 800HP sometimes more but most guys who do that can't drive them everyday because to leave a stop light with that much power is really hard without spinning.
    -Kirk
    Dec 06 2007
    Quote Originally Posted by 317ssayzarc View Post
    Huh?
    sorry i meant pushing
    -Kirk
    Dec 05 2008
    Yea that would kill daily drive ability
    Dec 06 2007
    costs way too much
    and Clint i know like Mike makes 800HP but it isn't drivable for the street someone needs a car like Jet Jockeys to turn one into a track monster
    -Kirk
    Oct 29 2005
    10speed
    San Francisco, CA
    yes, if you guys want to actually see people do cool stuff, you need to go to Vortex 1.8T forum... They actually make power
    dude... There are VW 1.8Ts making 700whp+, our motor can make it also
    - Clint
    Dec 05 2008
    costs way too much
    I didint see where anyone made 800, thats along way from the stock hp.
    Dec 05 2008
    [/QUOTE] dude... There are VW 1.8Ts making 700whp+, our motor can make it also[/QUOTE]
    Are they Daily Drivers ?
    Oct 27 2007
    In the lab
    Wow Audi guys are so uninformed...
    You guys need to go spend a few weeks in the Vortex 1.8T forum, then revisit this subject
    Oct 27 2007
    In the lab
    Damn you! You beat me to it!
    Oct 27 2007
    In the lab
    Are they Daily Drivers ?[/QUOTE]
    Frankies was semi-daily... Think those 1000hp Evo's are dailys haha?
    Jul 08 2007
    2007 2dr 6spd gti
    Hillsborough
    alot of evos also dont run the stock block.... theres an aftermarket one im not sure the name that is used alot and its just incrediably strong
    its in alot of those crazy dyno videos they dont use the stock block
    Dec 05 2008
    [/QUOTE] Frankies was semi-daily... Think those 1000hp Evo's are dailys haha?[/QUOTE]
    There were several in Modified Mag that were driven down to Florida for the 1000 hp shoot out last year.
    Dec 05 2008
    Quote Originally Posted by GTIBONO View Post
    Oh thats right there is an after market block for them i think Slow boy racing makes them
    Oct 27 2007
    In the lab
    There were several in Modified Mag that were driven down to Florida for the 1000 hp shoot out last year.[/QUOTE]
    Doesn't mean that they are daily driven... Shit, if you can afford the earmuffs, tickets, race gas, and engine teardowns go for it. I guess you could daily it haha....
    http://forums.vwvortex.com/zerothread?id=3945260
    That was on a motor just under 2.0
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    It is very simple, without a 11k rpm rev limiter a 2 liter is just not going to make 1000whp.
    But once you throw in the extra driveline loss of the quattro that 700fwhp becomes 600awhp.
    Nearly 100% of the big hp EVO's are Shop Cars and are strickly used for drag racing or as a dyno queen.
    Buncha motorcycles
    Memphis, TN
    kirk, i think you meant there is no replacement for displacement
    and like clint said, they have huge aftermarket support, their regular FMICs are 1000 cu in whereas our ER comp is 600 cu in.. and have the ability to be made to 2.2/2.4s
    an a4 was never meant to be what some have turned them into.. evos are built for the track from the get go
    Dec 06 2007
    ^^yes i did sorry haha my brain is somewhere else today.
    -Kirk
    Jun 08 2008
    Calgary AB Canada
    I still dont understand why anyone would ever build a car just to run it on the dyno all day long...
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by onceover View Post
    there are a BUNCH of street driven 500+awhp Evos though
    - Clint
