    Registered Member Two Rings bnb5550's Avatar
    Oct 09 2006
    06 S4 25th Ed. 07 S6
    Loomis, CA
    How much fluid do I need for a complete brake flush on my 06 S4?
    Been hearing all kinds of different numbers, 1 liter, 1.5, 2.5-3. No idea whats right but at $18 for a half liter I'd like to know so I don't accidentally buy twice as much as a I need. Just getting some higher performance stuff before I go to a track day.
    Have it narrowed down to ATE blue and the Wilwood 600 stuff.
    Nov 19 2008
    San Jose, CA
    Re: How much fluid do I need for a complete brake flush on my 06 S4?
    I just did my '05 with 1.5 liters of Motul 600, and that was plenty. Usually I can reduce the amount of fluid required by withdrawing all of the old fluid from the reservoir with a baster, but the S4's design puts something in the way that prevents that.
    That price seems high, I seem to recall ATE Super Blue runs about $12-15 or so a liter.
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    Yea ATE should not run you more than $15/l
    |^^^^^^^^^^^\||____
    | The STFU Truck |||""'|""\__
    | _____________ l||__|__|_|
    Oct 09 2006
    Loomis, CA
    Quote Originally Posted by ClarkSJ View Post
    Yes, ATE is $12 a liter from tire rack, but both Wilwood and Motul are more than that for 500 ml. Trying to decide if they are worth the extra cost.
    Nov 28 2007
    04 S4,Volvo P1800,03 Silverado
    Massachusetts
    i stay stick with ATE blue.. i use it on my audi and motorcycle.
    04' Nogaro S4 - 19" BBS RS-GTs - H&R Coilovers - Hotchkis RS4 Sways - 4500k HID fogs - JHM solid shifter trio -JHM intake manifold - JHM port matched intake spacers - JHM longtube headers - JHM tune - Fast Intentions resonated catback - Snub mount - Vag mods - hardwired V1 - Clutchmaster Stage 3 clutch & 13.5 lb flywheel - Euro B7 RS4 steering wheel - Cayenne Big Reds - stern engine mounts - Stern upper control arms - K&N panel -
