Results 1 to 14 of 14
Thread: Losing coolant
    Registered Member One Ring Madsen's Avatar
    Dec 31 2007
    Audi S4 2,7 Avant Facelift
    Norway
    Losing coolant
    Hello.
    I have a 99 s4 avant (facelift).
    In a few months now i have to refill the expansion tank about ever 2-3 weeks. And its white smoke (not so much smoke when its hot)
    I cant find a leak anywhere, and you cant see any pond under the car.
    Yesterday i started to take apart the car (because off the fan dint work)
    And i have been reading much about the aux water pump.
    So i got some pictures off my pump, can somebody tell me if its the pump that has leaked? Or do anyone have a idea what it can be? I just dont hope its the head gasket!
    If it is the pump, should i switch it to a new one or take it away?
    Tanks for answers:)
    Audi S4 2,7 Facelift
    Nissan King Cab 4X4
    (X)Audi S4 2,2T Avant
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    Re: Losing coolant
    IMO replace it look at the dried coolant on it
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Re: Losing coolant
    Well you definitely need to replace that pump. Is the white smoke you are talking about coming from the exhaust or from the engine bay?
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Dec 31 2007
    Norway
    Re: Losing coolant
    The smoke comes from the exhaust.
    I`m pretty sure that it is the pump, but it dosent hurt to ask:P It cost pretty mutch here in Norway.
    Tank;)
    Its just so boring to bolt everything together and it still leaks.
    Nissan King Cab 4X4
    Jun 14 2007
    2000 S4
    Connecticut
    Re: Losing coolant
    yeah I'd replace that. I just had mine replaced but it wasn't half as bad... Maybe it would be cheaper to buy it here and have it shipped?
    Veteran Member Four Rings obijohn22's Avatar
    Dec 02 2007
    2001.5 S4, 2013 ZL1 Camaro, 2013 Jetta SE
    michigan
    Re: Losing coolant
    What does your expansion tank look like? Have you replaced that yet? The early ones crack and leak under pressure. But still def. replace that aux pump. good luck.
    "NIGHTMARE" Stage 3+ 2001.5 Brilliant Black S4. VAST sauce
    My shit goes like whoosh boom pshhh and like vroom and junk. So fast.
    Dec 31 2007
    Norway
    Re: Losing coolant
    I havent looked so mutch on the expansion tank, but if the expansion tank leaks want you see it under the car? (but i will check it, where does it use to crack?)
    Yes its cheaper in usa but i looked on autohausaz.com, but i have engine code AGB but on autohausaz it is APB. Maybe it is the same?
    Nissan King Cab 4X4
    Dec 02 2007
    michigan
    Re: Losing coolant
    It depends on the leak. Sometimes under pressure it will just drip. and if it drips down onto the turbo or dp, there's your smoke and no puddle. if your expansion tank is not WHITE (if it has a yellowish hue) and you can see white lines in it, they are little cracks and you need to replace it. If it doesn't leak now it will eventually. these small cracks can begin to leak under pressure. If it is white in color, it should be the new material and you should be ok. It is likely that your aux pump is leaking based on the pics, but you should check this too.
    Dec 31 2007
    Norway
    Re: Losing coolant
    Yes i have the yellow tank.
    Then im going to order the aux water pump and look at the expansion tank.
    Thanks guys:)
    Ill let you know if the problem disappears.
    But the white smoke from the exhaust, what can that be? It still has the orginal turboes from 99 and the car has 190000km thats about 120000mile. Maybe they have seen better days:P
    Next time somethings wrong i guess it going to be stage 3;)
    Nissan King Cab 4X4
    Jul 06 2007
    San Jose, CA
    Re: Losing coolant
    The smoke from the exhaust could be the turbos going. That or a bad head gasket.
    Established Member Two Rings crosenhahn's Avatar
    Mar 13 2008
    2001 Audi S4
    Colorado Springs
    Re: Losing coolant
    Madsen - how difficult was it removing the aux water pump, mine is leaking and I need to replace it? did you have to replace any gaskets? Thanks!
    01 S4 - Stage 2+
    Veteran Member Four Rings wdbdy2000s4's Avatar
    Oct 08 2008
    1998 pathfinder, 2000 s4
    MA
    Re: Losing coolant
    Check your oil regularly. If you're turbos are burning oil you're gonna want to know so your motor doesn't seize up. Happened to a buddy of mine with an eclipse, his motor seized on the way to go buy oil.
    Frimmel: i only speak when i have something negative to say.
    Grah4m: i lost to a giraffe. be careful out there.
    ThirdStrike:leave your feelings at the keyboard
    Dec 31 2007
    Norway
    Re: Losing coolant
    Quote Originally Posted by crosenhahn View Post
    No, just remove everything on top off the engine (covers, turbo hoses, etc) screw out every screw to the intake, and then you can just lift it upp in the front.
    Im going to switch out the intak manifold gasket.
    But check this link if you dont want to remove the inntak: http://forums.audiworld.com/s4/msgs/2169710.phtml
    I have removed everything on the front off my car because accessory belt tensioner broke in pieces when i drove.
    Nissan King Cab 4X4
    Dec 31 2007
    Norway
    Re: Losing coolant
    Quote Originally Posted by wdbdy2000s4 View Post
    My car dosent use any oil, but tanks for the heads up;)
    By the way, i checked the expansion tank today. It was about 8-9 cracks in it
    Nissan King Cab 4X4
