Results 1 to 6 of 6
    Veteran Member Four Rings Big Boost's Avatar
    Jan 28 2008
    S4VRT
    Milwaukee, WI
    Suspension/ Control arm deflection
    When the S4 is being launched, does the front and rear control arms deflect towards the rear? The reason I am asking is that has anyone ever built a set of traction bars for the front to eliminate the possible deflection?
    2015 Audi A3 Stage 3+
    2001.5 Audi S4 VRT
    Mar 20 2008
    Italy
    Re: Suspension/ Control arm deflection
    WTF???
    RS4 B5
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    I believe traction bars are only for cars with a live axle.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Veteran Member Four Rings veggiemonster's Avatar
    Oct 20 2008
    fuck off
    no hes talking about a bar that goes from the frame to a control arm. FWD cars use them a lot to eliminate wheel hop.
    i dont think and s4 needs one unless you ran slicks but thats just me
    Mar 20 2008
    Italy
    RS4 B5
    Jan 28 2008
    S4VRT
    Milwaukee, WI
    Yep. I had one made for my old school SE-R turbo, and it cut .2 off my 60ft time. I took it off, and lost .2 consistently. It helped with street tires as well. Just thinking aloud.
    2001.5 Audi S4 VRT
