Results 1 to 22 of 22
    Veteran Member Four Rings veggiemonster's Avatar
    Oct 20 2008
    fuck off
    coilover questions
    what kind of coilovers do you guys think are the best for the value?
    or what will allow you to go lower than the rest?
    Veteran Member Three Rings 2BblkAudis's Avatar
    Feb 15 2007
    San Mateo, CA
    Re: coilover questions
    I know H&R has an ultra low kit.
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    You can pretty much put the car on the ground with our Vogtland kit.
    Not that I'd recommend it at all.
    Veteran Member Four Rings wdbdy2000s4's Avatar
    Oct 08 2008
    1998 pathfinder, 2000 s4
    MA
    ^ the vogtland kit or slamming it to the ground? lol
    Frimmel: i only speak when i have something negative to say.
    Grah4m: i lost to a giraffe. be careful out there.
    ThirdStrike:leave your feelings at the keyboard
    Senior Member Two Rings dennisS4's Avatar
    Mar 23 2008
    Tri State aRea
    Quote Originally Posted by wdbdy2000s4 View Post
    haha X2, that wouldn't be smart to talk down about your product.
    I have vogtlands and with 19's you can go real low if you want but bottoming out is inevitable with being so low.
    Veteran Member Four Rings espo4442's Avatar
    Jan 14 2008
    Carlisle, PA
    Quote Originally Posted by dennisS4 View Post
    I'm pretty sure it was obvious he meant slamming the car lol
    2010 Brilliant Black/Magma Red S4
    Oct 20 2008
    fuck off
    teh specs on your website say 1.5-3 in. does that mean +1.5 to -3.0 range or what?
    Oct 08 2008
    MA
    it means that it will drop the car 1.5 inches to 3 inches depending how you set them. An s4 would look like a monster truck with a 1.5" lift, lol
    Oct 20 2008
    fuck off
    well yeah. but i was just clarifying. so its lowered 1.5 on the highest setting?
    Oct 08 2008
    MA
    exactly
    Jul 19 2007
    San Diego, CA
    The height range specs are to TUV sepcifications, which don't necessarily match actual ranges. Actual height ranges are more like -.5" to -3.5".
    Oct 08 2008
    MA
    Owned...thanks for the info mike!
    Oct 20 2008
    fuck off
    thank you very much!
    Oct 31 2007
    F21-e85 S4 MKIV BPM R(T)32
    Grand Rapids, MI
    Why would you slam a B5 S4?? If its for looks, buy a different car!
    MKIV BPM R32 (DD)
    2000 B5 S4 3L GT2860 build in progress...if only I could get my parts quick enough
    Veteran Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    2014 BMW M235i 6MT, 2010 Audi S4 6MT
    Toronto, Canada
    Quote Originally Posted by 2fastS4 View Post
    Why would you slam a B5 S4?? If its for looks, buy an A4!
    fixed it for ya.
    Oct 20 2008
    fuck off
    why does my car need to be to your standards? oh wait. this is audizine....
    Nov 27 2007
    2000 s4 black : 03 600rr Black
    NOVA, VA
    has anyone run the tien basic coilovers? the specs are below, I just ordered some cheep as balls. I'm a little nervous coming from the subaru world where tein is not thought of as a making quality products, that and the front spring rate
    https://www.raceinspired.com/pc-2470...1998-2002.aspx
    Sep 27 2007
    00 S4 6sp, 06 Mazda3 HB Auto
    Columbia, SC
    Ya the Teins seem way too high up front, with 900 lbs you might be able to feel rice grains on the pavement.
    Vogtlans run 550-590 up front (progressive) and 510 out back (linear) front what I have read online.
    00 B5 S4 - K04, Stern Soft MM, Stern Snub, DTS, Neuspeed Rear Sway, Oinkies, GIAC stg 2 XR, Vogtland GT, SSAC copy. Soo... Stg 2.31456?
    06 Mazda3 - Wife's car and autox car
    96 Eclipse GSX - Gone
    03 Acura CL Type S - Gone
    96 Soarer GT - Gone
    93 RX7 R1 - Gone and missing her
    Nov 27 2007
    NOVA, VA
    maybe i'll just Rodney King them until they start complying, or schedule surgery for the herniated disk that will ensue
    Oct 08 2008
    MA
    Why are the spring rates soo high? is it a shitty shock body that would bottom out if the spring rate wasn't like 80000lbs?
    Sep 27 2007
    Columbia, SC
    Well...
    Ohlins run up that high as well, but the rear is closer in rates to the front, maybe even a smidge higher.
    Granted this is their race setup thou.
    96 Soarer GT - Gone
    Veteran Member Four Rings LJH's Avatar
    Oct 03 2006
    '84 Ur-q, '04 S4 6MT, '08 Outback XT 5MT
    Quote Originally Posted by sdoherty_tjm View Post
    Anything much lower then 25.5" really hurts the handleing of the car IMHO. I have Vogtland GT's and once the car settled in at 25.125" it felt really bouncy. Bumped it up to 25.5" and it feels great now.
    remember form follows function....
    Cheers,
    Jim
