Results 1 to 8 of 8
    Mar 21 2008
    Somethings bent but cant figure out what
    So i hit a curb with the back driverside wheel... turned out the wheel was bent so i replaced that. Bring it to Mavis to get a alignement and they say somethings bent but we cant figure out what... Bring it to another mechanic and they also cannot figure out whats bent. Im just stuck at what i should do next. Should i just replace the Control arm and start there? Is the Control arm something i can do myself?
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: Somethings bent but cant figure out what
    It's a finite amount of things it could be, control arm, tie rod subframe, axle, but I'd get it diagnosed correctly before just replacing parts. They couldn't figure out what it was from an inspection??
    08 S4- Stock SOLD
    Jun 01 2008
    Apopka, FL
    Quote Originally Posted by mholme View Post
    the rear control arms are cast iron iirc, I don't think they'll bend more than break. Are we sure the OP took the car to a mechanic that acutaly knows how to perform an alignment on these cars?
    Veteran Member Four Rings quattro16's Avatar
    Feb 05 2007
    Long Island, NY
    Finding things bent is not an easy task. Could be bent ever so slighlty the eye cant tell. The best thing to take the wheel off and use a tape measure and measure different points on the, spindle,upper arm, sway, bearing etc.... Then compare with other side. My bet is either the spindle or upper arm. Also what couldnt they get in spec, Camber or Toe. That will point you in a better direction!
    BetaAlphaTauMember #17
    20 Year Audi Master Guild Technician
    Long Island, NY. Instagram @andyaudiman
    Mar 21 2008
    Yeah theres no bends visible. Tape measuring each side is a great idea to start with. Everything was -.** i forgot the Exact numbers i have the sheet at home for the alignment of only the wheel i hit of course.
    Mar 29 2005
    MKE
    take it to a real shop and they'll find the problem. I'm betting it's the lower rear control arm.
    B8S4|P+ 6spd, AWETouring, RocEuro, H&R OE/Bilstein/034 RSB, APR Stg2 DP + CPS, TSW Bathurst 19x9.5, Michelin PSS
    Past:B5A41.8TQM, APR, celebrations, HID retrofit
    B5S4 6M|APR stage2+, APR catless DPs, APR exhaust
    B7A42.0TQM S-line, APR 2+, RS6 18"s, RAI cat, AWE exhaust
    BMW 540i-6M|BMW 528i|93 Maxima SE|383 Camaro Z28|Jeep WJ|11 Frontier Crew 4x4|06 Saab 9-3 Aero|01 Saab 9-5 Aero|06 Acura RL
    99 Yamaha YZF600R|05 CBR F4i|01 Aprilia RST1000|99 Ducati ST2
    Mar 21 2008
    So what are the options it could be ?? The control arm , spindel ...?? ...??
    Mar 21 2008
    Are these rear parts diffrent from an A4?
