Step 1: buy LED (39mm festoon) bulbs from fleabay.
Step 2: buy (1) 15-25 watt 25 ohm load equalizer (tap splices included) - http://autolumination.com/equalizers.htm (i actually have one that i can sell)
Step 3 (optional): get some 14-gauge wire (about a foot or shorter) and (1) butt connector
Step 3 (optional, but more effective): remove license plate
Step 4: using a small phillips screwdriver, remove light housing...be very careful, these suckers strip VERY easily
Step 5: remove trunk cover. there are (4) 20-Torx screws. 2 are on the handle side, and 2 are inside the light bulb cover which you can remove using a flathead screwdriver. yank down on the cover to remove, there's about 6-8 clips holding it in place.
Step 6: On the power cable going to the license plate area, there's a plug w/ 4 wires. the power (+) you want to splice into is the Grey/Brown (i'm semi color blind and that's what it looks like to me)
Step 7: Attach spare wire and butt connector (unless you wanna be a real man and solder the wire together).
Step 8: Run wire and load equalizer behind the metal body panel. I only did this b/c the equalizer gets hot and this way it doesn't touch anything that can melt/burn.
Step 9: Strip the end of the wire and ground using the bolt pictured. It's located on the passenger side inside the black plastic protection cover.
Step 10: Test bulbs...if successful, reverse to put back together
Step 11:
