Results 1 to 7 of 7
    Dec 11 2008
    AWE Resonator removal
    Hey all... I just picked up my S5 and had the AWE exhaust and downpipes installed. Great sound!!! I am considering removing the resonators on the system. Would you think an X pipe would be best?
    I am assuming the X pipe would replace the resonator in this picture (looks like a small muffler)
    http://http://www.awe-tuning.com/media/products/awe/S5_exhaust/AWE_S5_Exhaust_system.jpg
    Or are they on the downpipes? http://http://www.awe-tuning.com/media/products/awe/S5_exhaust/AWE_S5_Exhaust_dps.jpg
    I saw a youtube video and it sounds nice.
    Thanks
    Veteran Member Four Rings fusionx's Avatar
    May 17 2008
    07 A3 2.0T
    Socal / Boston
    Re: AWE Resonator removal
    the things on the downpipes are your cat's, keep those or you wont pass smog lol. Looks like theres only one resonator on the exhaust in the first picture, it looks like you could just get the resonator cut off and weld a pipe on each exhaust tube, nothing fancy
    07 A3 2.0T S-line - REVO stage 2 - GIAC DSG Flash - AWE downpipe - Custom staggered quad-tip exhaust - H & R springs - H & R sway bar - Neuspeed CAI - fog housing LEDs - VMR boost gauge - JL 12'' Sub w/ Precision Power Amp
    Instagram: @superseany
    CanyonRacerMotorsports
    Project Matte Black: COMPLETE
    Dec 11 2008
    Thank you...
    Senior Member Three Rings 15DGR V6's Avatar
    Jan 09 2009
    2018 Audi TTRS
    Cleona, PA
    Quote Originally Posted by fusionx View Post
    There's also a set of cats integrated into the exhaust manifolds, which is where the secondary O2 sensors are located. That's probably why you can get away w/eliminating the secondary cats. I think I'll be keeping the secondary cats when I replace my downpipes.
    Jan 19 2009
    Scotland
    I read on another thread somewhere that according to AWE the downpipes did not have cats at all, they were just resonators.
    And as someone has pointed out the cats are integrated with the manifold.
    I have also thought of taking that last resonator off, but wasn't sure about it passing emmisions testing, also would it be possible to have it cut off in such a way that it could be put back on at some point?
    Jan 09 2009
    2018 Audi TTRS
    Cleona, PA
    You could cut it out & weld v-band clamps on it & a test pipe. That would allow you to easily swap between the two. V-band clamps aren't cheap but they are what you'd need to do what you want to do.
    I'm not sure if they're resonators or cats since I haven't looked at the inside of a downpipe. But, from the outside, they look more like cats than resonators. I read somewhere that secondary cats are common on direct injection gasoline engines. Not sure if VW/Audi do this or not, though. The guy that looked at my car to size up a custom exhaust thought they were cats also.
    Jan 19 2009
    Scotland
    Thanks for the idea about the v-band clamp, i'll look into it a bit more.
