Results 1 to 4 of 4
Thread: Hissing clutch
    Veteran Member Four Rings FITZ TITS's Avatar
    Phila
    Hissing clutch
    I have an OFE SS clutch and when I slowly engage the clutch is hear a hissing until I'm fully off the clutch pedal. I hear when I'm inching forward, no gas, just slowly letting the clutch out. Is this noise bad?
    Veteran Member Four Rings martini's Avatar
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    Re: Hissing clutch
    Quote Originally Posted by rcfitz86 View Post
    my clutch was making a bit of noise when the throwout bearing went bad. I think there is a plastic part between the throwout bearing and the pressure plate that can separate and then spin in place.
    im not saying that is what this is... just a comment
    yours sounds like its during the engagement, as if the clutch slip is actually audible. Did you get the pressure plate resurfaced when you did the clutch? You may want to search around for 'separating clutch' or something like that A couple of people got some OFE SS's that the organic side seperated from the rest of the clutch. In that case, I would imagine there would be some hissing/spinning noise
    a4mods.com Stickers!
    http://www.a4mods.com <-- Thats my website!
    - My vehicle is stock.... I promise -
    - BetaAlphaTau member #4 -
    Phila
    Re: Hissing clutch
    Quote Originally Posted by martini View Post
    I had the option to get the flywheel resurfaced, but I didn't. I should probably have this looked at.
    Buncha motorcycles
    Memphis, TN
    Re: Hissing clutch
    mine does it too... you can only really hear it like in the garage when you let the clutch out slowly with no gas... its done it for 10k without trouble
    APR Stage 2/AWE Intake
