Results 1 to 9 of 9
    Oct 20 2008
    new York
    Emissions Failed. Help!!!
    My check engine light has been on for awhile now and it was inspection time. Long story short my car threw 2 codes. My only question is do I have to replace the left rear O2 sensor?
    17530 - Oxygen (Lambda) Sensor Heating: B2 S2; Open circuit P1122 - 35-00
    17548 - Oxygen (Lambda) Sensor; Bs S2; Internal resistance too high P1140 - 35-00
    I tried resetting the ecu to no avail 3 times so I think my only option is replacing the sensor, but is there anythign else I need to do based off the VAG?
    Thanks
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: Emissions Failed. Help!!!
    B2 S2, driver side rear(lower) sensor needs to be changed. What kind of emissions test do you do in your state, just OBD testing? As long as you pass your readiness test in a VAG COM, you shouldn't have a problem passing emissions. Did they even let you test with a CEL?
    08 S4- Stock SOLD
    Oct 20 2008
    new York
    Well the CEL wasn't on immediately when they began the test. Like I said I attempted to reset 3 times and kept my fingers crossed, but it didn't work out. So the B2 S2 is the drivers side? He told me passenger side. I'll take your word for it.
    Thanks.
    Senior Member Two Rings YnotS4's Avatar
    Jun 22 2008
    S4
    Chicago
    You can reset on a vag or an OBDII dianostic tool. You may be able to drive a few miles before it comes on again, borrow a OBDII from some one local. This worked for me.
    Oct 20 2008
    new York
    Yeah the guy at the shop reset it on the VAG. He said if i hit 50 miles w/o it coming on bring it back. Otherwise replace the sensor. I guess I'll just order the sensor, not that big of a deal, could be worse.
    Veteran Member Four Rings Quattrocket's Avatar
    Sep 02 2004
    2001 Audi S4
    Guelph, Ontario
    TIP : Go to an emissions shop that only has a 2 wheel dyno they will do a rev test and you will pass.
    MITCH
    "Audis are like strippers. They only work when you throw money at them."
    FORGE MOTORSPORT DVs*K04 TURBOS*034 TURBO INLETS*STAGE 3 SOUTHBEND CLUTCH(MANGLED PP MOD)*
    Apr 18 2007
    ny
    No more messing around with inspections in New York, there was a way around everything before but not anymore with OBDII scan.
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    Quote Originally Posted by Quattrocket View Post
    Not entirely true. Many states don't even put ODBII cars on dynos anymore, many states just perform a visual inspection and an ODBII readiness check. Sounds to me, in the OPs state, you have to pass ODBII.
    It could be all states (Federally) are like this now in the U.S., but I'm not sure. In my state if you've got ODBII, there's no dyno for you.
    Sep 27 2007
    00 S4 6sp, 06 Mazda3 HB Auto
    Columbia, SC
    Quote Originally Posted by tdn View Post
    No vehicle inspections in FL.
    00 B5 S4 - K04, Stern Soft MM, Stern Snub, DTS, Neuspeed Rear Sway, Oinkies, GIAC stg 2 XR, Vogtland GT, SSAC copy. Soo... Stg 2.31456?
    06 Mazda3 - Wife's car and autox car
    96 Eclipse GSX - Gone
    03 Acura CL Type S - Gone
    96 Soarer GT - Gone
    93 RX7 R1 - Gone and missing her
