Results 1 to 16 of 16
    Veteran Member Four Rings AudiOso's Avatar
    Aug 04 2007
    Do Hotwheels count?
    Boardman, OH
    Question What driver to remove MAF screws?
    Okay... So I have a P0171 code throwing on my Avant. I've fixed the vacuum leaks. I replaced a defective check valve. Now I need to clean the MAF because I might of have over-oiled my K&N the last time I cleaned it.
    So I go to the parts store and buy a set of tamper-proof torx bits and the brake cleaner. I'm all set. WRONG!!! The stupid screw is not a torx (six points) it's a five point tamper proof fastener.
    So where do I get the driver I need? No, I'm not going to slot the screw or mangle it in any fashion. I want the right tool for the job. Anyone know what's up here?
    A couple of Audi's later...
    "It's a false state of elation... You can join the Prozac nation... If you want to..." - Killing Joke
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Re: What driver to remove MAF screws?
    Call up Napa. I know Klann manufactures them too.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Looks like the one in the top left corner? Not the 2nd from the upper left (tamper-proof Torx)?
    -Doug
    Aug 04 2007
    Do Hotwheels count?
    Boardman, OH
    Hey Doug... It looks like the second from the top left but it has five points instead of six.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Never seen those before.
    Get a small torx or allen wrench and hammer it in there to gain torque. Then spin 'em out. Buy new screws.
    OR, try some needle-nose pliers. That worked when I had to remove my ballasts from my Xenon headlight housings. I then replaced the screws with stainless steel screws.
    -Doug
    Feb 12 2004
    Everywhere
    Needle nose vise grips might work even better. I know you didn't want to mess them up but honestly I'd just cut a slot in it with a dremel and get it out with a flat head screw driver. Then reinstall new ones that are normal torx style or phillips. Might save you tons of time if you can't find the 5pts around and have to order them... Mine are still in there with the slot cut out. Was just too easy to do it that way. No one is looking I swear ;)
    On a side note, I have never seen 5pts on an audi before... maybe yours was taken out at some other time in the past?
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by CO AVANT View Post
    That is what I was thinking.
    -Doug
    Veteran Member Four Rings HIERLEVELZ's Avatar
    Apr 16 2007
    Queens
    Yup like the others have said grab them with a st of pliers and turn them out or cut a slot with a dremel. i've used bother methods but the pliers were the easiest.
    BetaAlphaTau Member # 31
    2003 A4 1.8TQM
    Jul 30 2008
    08 Passat 2.0t
    Near Mountain Creek
    VAG started using the 5-lobes a few years ago.... I have seen them on TDI MAF's.
    www.metalnerd.com
    that set is $50
    this is $9
    plus shipping of course
    08 Passat wagon 2.0T 6MT (APR Stage I, DriverGear-Eibach springs, Bilstein Sport, Euro smoked tails, intake, ATE Premium One rotors, Hawk HPS, Tyrolsport Caliper Guide Bushings, other stuff)
    Previous Cars:
    02 Golf TDI 5MT (Chipped, Bosio PP764 nozzles, VNT-17, Shine Racing suspension, S3 strut brace, WRD rear strut brace)
    88.5 Camry V6 5MT
    84 Corolla 3AT (the FWD version, hand-me-down)
    Dec 03 2005
    2 pedals 1FG
    connecticut
    UGwagen
    Thanks for the info. You learn something new every day.
    -Doug
    Aug 04 2007
    Do Hotwheels count?
    Boardman, OH
    Is it the T25 or the T27? I found them on MAC Tools website for $5.49 ea and just want to order the one I need.
    Feb 12 2009
    clean 03 4tro
    so cali
    Guys I saw this thread and need help. I need to buy 2 new screws and nowhere near a dealership. No one answered with what the size thread or length of screws, what size screws are these? I only have autozone and kragen and pep boys for help. I am in need of these asap.
    thanks
    Dec 26 2009
    dc
    I got a set of hollow-middle tamper-proof set at MicroCenter (yes, that's a computer shop) for $3 dollars (made in China). There is another, Taiwan set but its $7 a set. Torx, Hex, twisted philips (4-edge), two edge, and three-edge - 32 tips in all. And yes, I used it to clean my MAF too - with near 90+ proof iso alcohol.
    2001 A4 Quattro 1.8T Manual
    Last edited by rexsolomon; 12-26-2009 at 11:23 AM. Reason: added total number of tips and my ride info 1.8T AWM
    Aug 26 2005
    To defeat the security screw, I break off the post in the middle of the socket. I used SS counter sunk socket head machine screws to replace the originals.
    Apr 12 2007
    Milwaukee
    Oct 15 2006
    From a few to one...
    Arlington, VA
    '97 A4 1.8TQ, '02 A4 1.8TQ Avant, '03 A4 1.8TQMS, '04 A4 3.0Q Cabrio - Sold
    '18 S4 Prestige - Kohlefaser Luft-Technik Intake
