Results 1 to 16 of 16
    Registered Member One Ring NYCQUATTRO's Avatar
    Mar 30 2006
    Quattro Vs Bmw Xdrive
    Veteran Member Four Rings KPC1.8TQuat's Avatar
    Mar 20 2006
    2003 A4 1.8T Quattro, 2006 Triumph Daytona 675
    North Shore, New England
    Re: Quattro Vs Bmw Xdrive
    They must have done something to tamper with the Quattro.
    Veteran Member Four Rings Exanimas's Avatar
    Mar 09 2008
    is full of crap.
    Boston, MA
    Front wheels on the Audi weren't spinning at all. They didn't even look like they were attempting to.
    -Nick
    2008 B7 A4 Avant 2.0T 6spd
    ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
    Active Member One Ring ELSNARLO's Avatar
    Jun 28 2008
    01 S4 Avant, 04 A8L, 91 200,
    Albany, NY
    Something is very fishy about that video.
    Jun 08 2008
    Calgary AB Canada
    hmmm?
    RWD A8?
    Veteran Member Three Rings davidlizard's Avatar
    May 01 2008
    2004 A4 ultrasport 6speed
    Winter
    Can't believe
    Unitronic stage 2+ / Borg Warner K04 / Milltek / ATP 3" testpipe / Racetec FMIC / Forge TIP / Carbonio / Forge DV / 386cc / 034 25mm rear sway /Joey moded / Podi / JHM 350mm BBK & SS lines / STaSIS street sport/ Michelin Pilot Super Sport / ECS Tuning lightweight flywheel + RA4 clutch kit /
    034 engine & trans mounts / 034 snub mount / 034 front & rear link / Apikol rear diff mount / JHM solid short shifter
    Established Member Two Rings smarrick's Avatar
    Apr 07 2008
    04 A4 18T 6MT QT SPORT, 07 X3, 74 Lincoln Continental
    Fort Collins, CO
    bs
    Fort Collins Drinking Team Member #2
    Veteran Member Four Rings downhillracer's Avatar
    Aug 20 2007
    97 Jeep Wrangler
    Costa Mesa / Mammoth Lakes
    Torsen Differentials deliver more torque to the wheels that have more traction. so this video is crap!
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Been discussed WAY to many times already...
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Veteran Member Four Rings Coderedpl's Avatar
    Jul 27 2007
    Orange County, NY
    Cmon guys!
    Its the A8 from the movie transporter!
    (for those who saw the newest know)
    Active Member One Ring gofast951's Avatar
    Jan 06 2009
    04' A4 1.8T Q 6mt Dolphin Grey
    Central NJ
    I smell a Rat!!
    Veteran Member Four Rings Jet Jockey's Avatar
    Jun 17 2004
    2017 B9 A4 Quattro/DSG/Technik/S-Line... 2004 B6 A4 1.8T Quattro race car
    Montreal, Canada.
    This is normal because the TorSen as to see some sort od differential between the front and the rear.
    Now what we don't know is and I suspect the ESP must have been deactivated. Because we have open diffs front and rear Audi decided to use ABS in reverse logic to give us a poor man's LSD.
    So if the ESP is functional it should up to a speed of 50 mph brake any wheel that's spinning to give it better traction which doesn't seem to happen here. In other words the traction control managed by ESP and ABS should be able do help out in situations like this.
    Of course there is nothing better than a mechanical LSD.
    Veteran Member Four Rings GTMRS4's Avatar
    Sep 14 2006
    New York, NY
    Quote Originally Posted by Jet Jockey View Post
    If I ran the rear LSD from Stasis would I completely negate the ESP?
    BetaAlphaTau # 18
    2007 Q7 4.2 Premium
    2007 997 Midnight Blue
    2005 Lotus Elise Magnetic Blue
    2004 B6 APR STGIII+ (SOLD but not forgotten)
    Dec 09 2008
    Wisconsin
    Are you implying there's no torque differential between wheels on rollers and wheels on pavement?
    It's physically impossible for that video to have an A8 with a functioning quattro. Well, unless of course they filmed it in a magical universe where you can back-drive a worm gear. If that's the case, all bets are off.
    Spiff, wondering if it really is the car from Transporter
    Aug 26 2005
    ESP and EDL are two different functions. ESP is involved with using the ABS to brake a wheel to counter a spin around the vertical yaw axis. EDL is involved with the ABS to brake a spinning wheel on slippery or low traction surfaces, to transfer drive torque to the opposite axle through the open differentials. Both also employ torque reduction as needed, but with a different control sequence.
    Electronic Stability Program/Electronic Differential Locking
