A few months ago my battery died and ever since I recharged it a few things were different.
1) My headlights were ALWAYS on no matter the position on the headlight switch
2)My "home safe" feature didn't work (when the fogs and tails stay on for 30 seconds after locking your car in the dark).
BUT now after everything is back together my headlights won't turn on at all. :/ maybe the codes will help out, hopefully it's something like a fuse.
Thanks.
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 F
Component: int. Lastmodul RDW 0517
Coding: 00011
Shop #: WSC 00000
10 Faults Found:
01494 - Bulb for Parking Lamps: Left (M1)
57-00 - Electric Circuit Failure
01498 - Bulb for Parking Lamps: Right (M3)
00978 - Lamp for Low Beam: Left (M29)
00979 - Lamp for Low Beam: Right (M31)
01495 - Bulb for High-Beams: Left (M30)
01499 - Bulb for High-Beams: Right (M32)
01504 - Bulb for License-Plate Light (X)
01493 - Bulb for Blinkers: Front Left (M5)
01497 - Bulb for Blinkers: Front Right (M7)
01800 - Light Switch (E1)
27-00 - Implausible Signal
Address 55 -------------------------------------------------------
Controller: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00060
Shop #: WSC 63351
2 Faults Found:
01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49)
30-00 - Open or Short to B+
01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48)
