Results 1 to 12 of 12
    Veteran Member Four Rings anmagro's Avatar
    Sep 14 2008
    Unhappy Need Help With Brakes. Price & Advice.
    Hey Guys,
    My brakes need to be done very soon. I need new Rotors, and Pads. This is the kit im looking at right now.
    http://www.awe-tuning.com/pages/shar...kes&IL=a4combo
    It gives me what i need with some better looking, preforming rotors, fluid and the cool option of steel brake lines. I dont want a complete $1500 overhaul of my brakes, so i think this is good.
    1. Can anyone find a kit like this for me at a better price? Maby with slotted instead of drilled rotors?
    2. Is this a quality kit? Sugestions?
    3. I have herd that doing rotors and brakes are not that hard but brake lines suck to do and they can dangerous if not done Exactly correct. Should i go ahead with doing the brake lines myself? I have only assisted on brake jobs.
    4. If having some one else do the lines is the better idea, can i install the rotors and pads myself and then have a shop do my brake lines for less of a labor fee?
    thanks guys. i really want to make sure i get this right. after all...it is the brakes. lol
    Black On Black 98' Audi A4 2.8L 30V 5spd. Quattro "Esabell"
    BBS RK's - Zimmerman - Vogtland Sports - Thrush Welded Cat-Back - DDM 6000 - Reigar RS4 - K&N Spectre - EbaySS - SpeedTuning Stage I
    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    Re: Need Help With Brakes. Price & Advice.
    link is not working
    00' Cactus, GIAC,H&R coilovers,original K03's for the time being..
    May 31 2008
    New York
    you should install the rotors and pads your self and then have a shop do the ss lines and bleed the system
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    rotors and pads are very easy... lines arent that difficult just have to make sure you do it right and make sure all the fittings are tight and dont leak. then bleed them and stand on the brake pedal to make sure none of the lines burst or leak. then you're good to go.
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Sep 14 2008
    Link is fixed. I would assume there are quite a few connections that need to be re done to replace the brake lines? And how would i get my car from my garage to the shop without bleeding the brake lines?
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    purems a8 bbk?
    TEAM|AXION
    Veteran Member Four Rings geeky's Avatar
    Nov 02 2008
    Boulder & Seattle
    Quote Originally Posted by speedydragon View Post
    purems a8 bbk?
    thats just for the front.
    I'd rather piece a kit together off purems. They have really good prices on rotors/pads etc.
    1989 Nissan 300ZX
    Lemons Race Car
    1999 Porsche 911 Carrera
    1-Off Widebody | LS1 Swap | AST 5200 2-way Remote Coilovers | blah blah blah
    2000 Mercedes Benz C230K
    The Daily | "VIP Build"
    2000 Audi A4 1.8T
    The New Track Build
    2006 Porsche 911 Carrera S
    LN Engineering 3.8L | H&R Suspension | IPD Intake
    Veteran Member Three Rings xraycer2012's Avatar
    May 28 2008
    B8.5 S4
    Here's what you should do:
    Get all four rotors from adam@spp in the group buy section here on AZ
    A8 sized rotors for the front
    Stock sized rear rotors
    He can slot, drill, dimple rotors or do a combination of either drilled or dimpled with slots as well.
    Here's a link to his thread http://www.audizine.com/forum/showth...ht=adam+rotors
    Get Audi TT caliper carriers from here because you won't find them cheaper anywhere else and they're great people:
    http://parts4vws.com/catalog/product...ber=8N0615125A
    and get some performance brake pads of your choice. I have Hawk HPS's and they're great.
    Don't bother getting stainless brake lines, IMO it's not worth the extra money. You're not going to feel much of a difference. However, with the bigger brakes in front. You'll feel a major improvement over stock.
    ‘23 RS6
    '14 S4 Nogaro Special Edition - Sold
    Sep 14 2008
    Ok, heres the scoop. Talked to my mech. I orderd this kit...
    And the guys is going to install everything for $380.00 because my mother and father refuse to let me use the garage for a week. Is this a good labor price guys?? It seemed ok. I just orderd the kit and im going to get back to him once it arrives.
    Nov 09 2006
    Bronx, NY
    a week? that shouldnt take more than 4 hrs
    2000 A4 1.8tq
    Registered Member Two Rings
    Apr 19 2008
    215 PA
    um at an actual techs point of view i flat rate that in 45 min.... brakes are easy as hell do it yourself.. your first time around it might take you 4-5 hours if you have never done it before and have never really been mechanical your whole life.. the ss lines they are over kill, i figured if ferrari dosnt even use them then why should i and also you want to change ss lines out every year due to the fact that they show no real signs of wear..
    Oct 25 2006
    oregon
    I wouldn't bother with the SS lines.
    I ordered the Stage one brake kit through Purems.com
    They have awesome pricing. $300 for the kit-including oversized rotors and new carriers. Noticed a little braking increasement, due to the fact I ordered better pads. No real reason for it to increase braking. If you're that set with SS brake line it shows them at $90.00, and if you want slotted or drilled thats about an additional $60 it shows. Get a good set of pads and you're at the same price as your other kit. If you do any spirited driving or tracking this set up is going to be a lot better for the same price.
    Very simple install. Don't be me and not torque down the drivers side carrier bolts though. Carrier slid off on I405, that ended up being a pretty crappy night.
