Results 1 to 40 of 51
    Veteran Member Four Rings rxrep's Avatar
    Feb 28 2006
    has nothing in it but memories.
    Pittsburgh-Philly
    Just 'cause I haven't posted headlight update pics in a few days...
    Ready for final sand-down, tab-hole cut out, then clear coat.
    Internals will go back in in the next few days. Still waiting on my LED's to arrive.
    Grilles almost done. Headlight casing isn't the straightest of weave, but in general it can't be seen and I only did it because I had scrap cloth lying around. I was more worried about the tabs than anything. The rest is just bling. I'm sure it won't be up to Winston's standards.
    Here is my front grille trim and rings, where the weave is more precise:
    My 2004.5 APR Stage 3+ is SOLD
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    Re: Just 'cause I haven't posted headlight update pics in a few days...
    I'm impressed.
    -Darrick
    Buncha motorcycles
    Memphis, TN
    that is ridicously nice
    APR Stage 2/AWE Intake
    Feb 28 2006
    Pittsburgh-Philly
    Here are some test-fit updates. Remember, this is only a test....
    Some parts aren't sanded, some aren't clear-coated. Others (like black trim along bottom and sides) haven't even been overlayed yet until my LED's are in.
    This is the downside of working in the winter in the gay-rage:
    Veteran Member Three Rings orangelmo's Avatar
    Jul 05 2007
    Stouffville
    Awsome work Lee... Just awsome!
    Veteran Member Four Rings Dolphin18T's Avatar
    May 17 2007
    That's some sick work, Lee! The fact that you wrapped the outside of the housing is ridiculous, but in a good way...
    -Ryan
    Maestro Tuned
    Now with slushbox-delete mod!
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    looks pretty good
    Oct 29 2005
    10speed
    San Francisco, CA
    Lee, farther away pics please
    - Clint
    Veteran Member Three Rings Dirty's Avatar
    Feb 07 2008
    05 A4 1.8T 6spd Quattro
    Orlando, FL
    ...enough said
    15 S6 4.0T Quattro
    DS1 stg1//B.E. TCU Tune
    S4 Door Blades//CC'd S4 Bi-Xenon//AWE Boost Gauge//RS4 Rear Sway Bar//K&N filter//Forge 007 DV//12" Audibahn sub-1500w//ATP 3" TP//Hitachi "E" coil packs//Revo Stage 2//FMIC & PS cooler//S6 LED's//RS style fog grills//Hawk HPS Pads//Tein SS Coilovers//19x10 et35f/et25r Rotifrom MIA's//Falken 235/35
    Feb 28 2006
    Pittsburgh-Philly
    Thanks. It's hard to see that the stuff that is clear-coated is really matte. The Audi rings trim shows it the best. But I couldn't get good pics of the headlight. Flash made the CF look gloss except for parts that aren't sand or coated yet.
    Which makes it look too busy with CF. It is more tame in person and the gloss is taken away.
    Veteran Member Four Rings golgo13's Avatar
    Apr 29 2007
    Tampa Bay
    where is the LED"S?????????//
    SweetnLou!
    Feb 28 2006
    Pittsburgh-Philly
    You nuts? It's pouring rain out there, lol. I'm kind holding off on those until the whole front is done, anyhow. The front end is pretty much in pieces right now and I had to put bumper back on just to test fit the headlights.
    In due time.
    Quote Originally Posted by golgo13 View Post
    Near as I can tell, somewhere between China and Pittsburgh. They shipped last week. There was extra time involved because they installed individual resistors on each LED for me. I'm hoping to dive in to that this weekend if they show up. Once they go in, then the rest of the overlay will be done on that bottom trim piece, and the small cut-outs at the bottom of the two projector trims will be covered by the LED strip portion.
    Feb 28 2006
    Pittsburgh-Philly
    Due to spacing, and how the projectors sit, I was toying with this LED idea. Thoughts?
    Maybe even rounding off the center corner and making it almost like a reverse of the A5/S5
    Veteran Member Four Rings Smiley's Avatar
    Sep 29 2007
    2002 Audi A4 1.8TQM
    Dubai, UAE
    I like your original concept much better..that doesnt look right
    Feb 28 2006
    Pittsburgh-Philly
    Yeah, me too. But there is more space to the center of the high beam than there is between the low beam and the turn signal.
    I may toy with moving the whole projector assembly over to make more room, but I don't want to screw up the beam pattern.
    Apr 29 2007
    Tampa Bay
    you put CF all over the headlight . Too much work ? come on, do it..
    [IMG][/IMG]
    BTW great work very awesome . Top notch
    SweetnLou!
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Wow.. that is sick and is defiantly trend setting.. nice work
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    Quote Originally Posted by rxrep View Post
    Why not just have a single line on the bottom?
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Veteran Member Four Rings Turbo1A4's Avatar
    Aug 04 2008
    2002 s4 nogaro
    Jax
    pure sex
    Active Member One Ring Mister Low's Avatar
    Dec 25 2008
    B7 2.0TQM S-Line, 00 R6
    KY
    Looks dope...solid work.
    Don't do the LEDs on the inside though, I think it will make the car look cross-eyed. Especially with only the LEDs on.
    Veteran Member Four Rings sambrody44's Avatar
    Dec 28 2007
    2002 Audi 1.8TQM
    Woodstock, NY
    Looks fucking sick man. It would have been cool if you had made the bottoms of the projectors flat. Either way it looks great.
    "set your mindstate free"
    2002 Audi A4 1.8TQM
    Lowered by Stasis SS (finally) On 19" ADR M-Classics.
    Bailey's DV
    Neuspeed Short Shift
    Southbend FE SS Clutch with AWE Flywheel (13lbs lighter then stock)
    Buy my photos here.
    Established Member Two Rings ggar015's Avatar
    Sep 24 2008
    2002 A4 3.0 Sport
    impressive!
    Veteran Member Four Rings TonyD's Avatar
    Aug 11 2007
    2012 135i tuned+meth'd
    California
    Too ricey?
    Dec 28 2007
    2002 Audi 1.8TQM
    Woodstock, NY
    I think just across the bottom for LED's would be cool.
    2002 Audi A4 1.8TQM
    Bailey's DV
    Buy my photos here.
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    Have the LEDs curve with the contour of the high beam housing.
    USP CLUB MEMBER #34
    Forum Moderator Four Rings docurley's Avatar
    UK London
    God dam they look sweet.
    Avus Audi RS4 2007 |Stock| Black optic | intake pipe| Android RSN-E| carbon knob Handbrake Airbag| LED interior & puddle lights
    Veteran Member Three Rings Elohite's Avatar
    Jan 14 2008
    San Antonio, TX
    love the cf in the housing. legit
    Garage Inc | APR | Britalman | 034| Stasis | Volk |Rotora | Deval | EuroGear | DTH | Thule | Forge | BSH | AWE | Evoms | H&R | Pioneer | JL Audio | TMA | ZiZa | KLight
    Buncha motorcycles
    Memphis, TN
    im lovin it like McDonalds! especially the rings
    Veteran Member Four Rings junkie1.8TQ's Avatar
    Dec 03 2005
    2004 A4 1.8TQ
    Charlotte, NC
    looks awesome... keep up the good work.
    also, you don't have room to do this version of the leds? This is still my favorite.
    2004 Audi A4 1.8T Quattro 6-speed
    • Bilstein PSS9 • APR Stage 1+ w/ TT225 Injectors • Forge 007
    • JHM SS • Oettinger RZ 19x8.5 • Podi • RS4 Rear Sway
    Veteran Member Three Rings bmags88's Avatar
    May 12 2008
    B6 1.8T A4 / 06 Lincoln Navigator(Ultimate)
    Massachusetts/S Shore
    That is awesome Lee!!! What kind of resin are you using?
    - Mags
    2003 1.8T A4 Quattro
    18" B5 RS4 Gunmetal Reps / K&N Drop-in / Helix Ecode Reps / Forge DV / DTH side skirts / 6000K Lows / OEM S6 LED DRLs / CF Beltline Trim / Blacked-out upper/lower grills / Parrot MKi9200 / Podi (Stewart Warner) Gauge
    USP Lower Front / S4 Grill
    Feb 28 2006
    Pittsburgh-Philly
    Quote Originally Posted by junkie1.8TQ View Post
    Because the single LED's I have coming are larger than the ones I'd used in this pic, they may be a bit big. It is very tight between the turn signal and the low beam. I am still pushing for this as my number one choice, though. The cheap knock-off strip I used in the design is very thin and uses tiny LED's, so it fits much easier.
    We'll know how it flows once the LED's arrive. I'm crossing my fingers it still fits and flows well.
    Quote Originally Posted by bmags88 View Post
    No idea. I have a gallon of it. And I realized quick that not much is needed. i still have 3/4 of a gallon left and all I need to resin now is my splitter. I got it on eBay. It's listed as CF-specific, UV resistant, and heat resistant. Hope I didn't buy snake oil. We'll see. I am using high-heat and UV resistant matte clear (4 coats for depth) also.
    [IMG][/IMG]
    You dream about this design, don't you? Lol.... It's growing on me
    Feb 28 2006
    Pittsburgh-Philly
    I think I'm going to try this one. It's still my favorite. I'm going to work up a mold tonight based on how big the LED's are and see if it works.
    Dec 28 2007
    2002 Audi 1.8TQM
    Woodstock, NY
    Sweet!
    2002 Audi A4 1.8TQM
    Bailey's DV
    Buy my photos here.
    Dec 03 2005
    2004 A4 1.8TQ
    Charlotte, NC
    Definitely my choice also... Can't wait to see the final product.
    Sep 29 2007
    2002 Audi A4 1.8TQM
    Dubai, UAE
    That design is just perfect. Flows very well with our limited "lines".
    You gotta do that man!
    Feb 28 2006
    Pittsburgh-Philly
    I'm also thinking of the straight-across the bottom pattern, however I'm trying to find a way to make it unique, since anyone with a hack saw can do that DIY. I just wanted to be a little different but still keep an Audi style, but I have my doubts that the space between the low beam and the turn signal is enough for the S5 style to look right with the LED's I have coming.
    Jun 13 2005
    Audi
    There's nothing wrong with the straight across style like the TT-S. Don't "force" the curved design into a B6 headlight if it wasn't meant to be.
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Feb 28 2006
    Pittsburgh-Philly
    Yeah, you're right. I've gotten a few responses that have said pretty much the same thing. I guess what will be "unique" at this point is the dual projectors and the CF. So what if the LED pattern is roughly the same as every other DIY out there. I just didn't want to look like every hack job that throws in some DIY LED's.
    In this pic, you can see how little space there is in between the low lens and the turn signal. It just won't work. The LED pattern would be cool, but if you looked at the whole housing with the LED's off, it just wouldn't work in a spatial-sense. In prior design stages, I was toying maybe curving up all the way at the edge.
    I think even with the straight-across TT-S style, I've got a few tricks that will separate it from the rest of the DIY's. It'll work. Thanks for the influence all.
    Dec 28 2007
    2002 Audi 1.8TQM
    Woodstock, NY
    You could follow the line of the inside of the headlight?
    2002 Audi A4 1.8TQM
    Bailey's DV
    Buy my photos here.
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    That is some nice work man.
    Good job.
    keep it up.
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
