Originally Posted by
barkerd427
They say on the link that they highly recommend the use of hood pins. The reason for this is that at higher speeds the latch can rip off due to the air running under the edge of the hood and creating tremendous lift. If you don't go fast then you would probably never need them, but you'll never see your max speed again. The hoods that don't require them at all have extra reinforcements for this exact reason. I don't know enough about this particular hood so I can't vouch for the construction of the latch attach point. Good luck with it.
agreed, hood pins are very functional. they prevent what barkerd said.
I am running the aerolatch pins, very stealthy. The only hood I know that doesnt need hood pins is vorsteiner. My buddy has it and we have gone well over 120 MPH and no problems.
Its simple, lighter the hood requires hood pins, heavier hoods might not. If you install the hood and when you drive over 80MPH and the hood looks like it is vibrating, than get hood pins, else you might be safe.
-randy
