Results 1 to 7 of 7
    Registered Member One Ring Gazza's Avatar
    Dec 08 2008
    Australia
    Octane Booster-Track Days
    I am planning to do some Track Days shortly and I have been recommended to add Martini-super octane booster in the fuel.
    I currently run my R8 on 98ULP and was wondering if anyone has tried any octane boosters and if they are of any benefit or just a gimmick.
    Thanks
    Senior Member Three Rings TWINTURBOA6's Avatar
    Nov 20 2005
    Audi A6 2.7T Quattro + more : )
    Rockville,Md
    Re: Octane Booster-Track Days
    you really don't need octane booster in your R8... The car is already fast! Just put your normal high octane in it...If it's not chipped just get the car chipped and make sure you get the right software for the right octane level...but again...you really really DONT need octane booster...it's a new engine/new car you DONT need that chemical crap in your engine!! ps it's not that healthy for your injectors/filter/pump/lines..... Also could possibly cause a check engine light...
    Audi D4 Technologist
    Audi Exclusive Service Consultant
    Join us at WWW.QUATTROKINGS.COM for more AUDI excitement!
    Veteran Member Three Rings VR4-S4's Avatar
    Jan 24 2008
    2013 S6, 2000 S4
    Columbus, Ohio
    It will not do anything for your car. Only thing octane booster is good for is if you are out somewhere and there isnt your cars recommended octane fuel available. You want to run your vehicles recommended octane, anything higher or lower will hurt performance.
    B5 S4 - PJK04's Vast E85 Tuned
    452AWHP, 475AWTQ
    C7 S6 - RS7 Turbos Vast Tuned
    B8.5 A5 - GIAC Stage 1
    B8 A4 - Stock
    Jun 01 2008
    Apopka, FL
    the only kind of octane booster is higher octane gas. the stuff you buy at autozone and walmart(or whatever chains there are in australia) raises it usualy by 5-7 "points"
    so if you put 93 in there and the octane booster you'd end up with 93.5 or 93.7 ect... which of course is *nothing* and very mis-leading, and expensive considering the 7 point stuff usualy cost $8-9 and higher octane gas usualy costs less for a whole gallon! That's not even mentioning that you shouldn't be running anything higher than 15% MTB's in your gas anyway. If you want to run pump gas and kick it up a bump, go to the paint store and get a gallon or two of toluene(114 octane) and mix that with however ratio you want for a higher octane.
    Veteran Member Three Rings ragazzi_07's Avatar
    Aug 07 2008
    Toronto, Ontario
    see if you can get race fuel. Its 100-110 Octane.
    They usually sell this at the track.
    That'll def boost it
    Jan 24 2008
    2013 S6, 2000 S4
    Columbus, Ohio
    Quote Originally Posted by ragazzi_07 View Post
    Race fuel will not do anything but harm your car if you arent running either higher compression or forced induction, and you need to be tuned for that. Run what its recommended your car is still stock
    452AWHP, 475AWTQ
    B8 A4 - Stock
    Apr 22 2007
    Riverbank, Ca
    No need for octane booster. Run it on your standard high octane fuel.
